door rubs fender
2009 model - bought new - daily driver , 41,000 miles. never in any type or accident or fender bender. just starting happening about 1 month ago. BOTH front door rub the front fender when opening door. what the hell happened? did the car shrink in this crazy cold weather in Chicago? how do i adjust the panel gap in between the front fender & door? it catches the fender on the bottom third of the front fender when opening door.
no, hinges are tight. funny thing - it's both front doors, & i am in the car 95% by myself - so the right front door is hardly ever used - so why, all of a sudden, both front doors are rubbing the front fender when opening?
Could it be ice build up? Ice will freeze below the hinges and make noise as if metal on metal. Mine did it yesterday.
Boydie
Boydie
when opening the front door from the outside, i can see the lower third of the door rub against the fender & makes a creak noise. when the door is closed, the panel gap looks good, but it catches & rubs on the fender.
fireballmail
May 7, 2010 06:12 AM
Goose
May 30, 2007 07:11 PM
