Dumb question about coolant and the turbo
Old Sep 23, 2019 | 04:31 PM
Didho's Avatar
(08 ss, auto trans) I'm replacing my turbo, and as I went to take off the top bolt on it closest to the firewall, my hand was covered in what I assume to be coolant. Am I correct in assuming that the turbo has coolant lines running it it as well as oil?
Turbo Is running 6psi, and falls on its face at 60, underboost code, piping looks fine, pressure test showed no leaks, so replacing the turbo is all I can think to do, tested solinoids, waste gate adjusted, everything.
Old Sep 23, 2019 | 05:00 PM
Yes, the turbo is cooled by the engine coolant.
How did you test the solenoids?
Did you inspect the bypass valve?
Old Sep 23, 2019 | 05:17 PM
Welcome to the site, what where the codes? Just the codes please.
according to this Cobalt SS site , yes the LNF turbo is liquid cooled.
https://www.cobaltss.net/forums/how-...o-pics-175853/
Old Feb 29, 2020 | 01:14 AM
Didho's Avatar
Wastegate adjustment
So I replaced my turbo about 6 months ago, and it's been running at 9psi,which is fine and dandy, but if I recall, these cars make 15 stock, so I'm guessing the turbo I purchased was turned down, does anyone have any tricks to get to the bolts/know about how much boost 1 full turn changes?
Old Feb 29, 2020 | 02:20 AM
Cat Man HHR's Avatar
Using Google in search box put in "wastegate actuator adjustment k04 turbo"
You will find a few on Youtube plus articles also.
Old Feb 29, 2020 | 09:21 AM
If you had answered our questions, we may have been able to help you figure out what was wrong with your car 5 months ago.
It was underboosting, so you replaced the turbo. Now it's still underboosting, you still think it's the turbo...
viper1996
20
Nov 7, 2017 08:33 PM
drspock
Apr 19, 2016 10:13 PM
Griff03
2.0L Performance Tech
13
Mar 7, 2010 09:21 PM
SPPD
Dec 19, 2008 11:05 PM
lou
Nov 16, 2005 07:29 PM
