Frt splash shield plastic rivets
Old May 27, 2011 | 12:38 AM
moonsign's Avatar
I'm having a hard time removing the frt. splash shield plastic rivets. I know there was a special tool, on here awhile back, that you could order, but can't seem to find the thread now.
Anyone care to enlighten me on best way to remove these darn things. "Moon"
Old May 27, 2011 | 12:48 AM
Here's the thread Moon, check out post #7 for the link to Harbor Freight.
https://www.chevyhhr.net/forums/show...ight=push+pins
Old May 27, 2011 | 02:20 AM
geg's Avatar
geg
In Russia it is done with scissors.
Scissors have are flat, but the blunt blades. They are easy to creep under the head of clip. At the same time, the long blades and scissors can be used as a lever.
The main danger - accidentally bite clip.
Office scissors do not work - is shaky. Use the tailoring scissors (bring your grandmother ).
Old May 27, 2011 | 08:53 AM
asanti's Avatar
To reiterate what 843de said, also look at post #10 as that's what I've done for years and it's worked with every car I've owned. (good ol' hammer)
Old May 27, 2011 | 06:11 PM
stanvalp's Avatar
just cut them off with side cutters, scissors, or a knife. replace with new ones. i found it wasn't worth the risk of breaking off the tangs of the plastic bumper cover so i just cut them off and got some new ones. beats fighting with them.
Old May 27, 2011 | 06:24 PM
If you are talking about the ones with the pin in the center, that operates like a "Molly" just pry the center pin out, then pop the rest out from under the sheathing. The other kind you can use a nail puller, or go to the local auto parts outlet and get the "body panel tool" kit, or a package of new rivets. Both kinds of rivets should be available at the "Zone,Boys,Advance" etc. try in the "stuff you never thought you would need" section.
rink 610
Mods - Exterior
Mar 22, 2012 09:44 PM
kingkat4
Apr 19, 2011 07:46 PM
Doctuh
May 20, 2010 12:10 AM
gunwaleman
Oct 29, 2008 05:46 PM
