HHr SS Electrical Problems Growing
Old Oct 23, 2021 | 11:19 AM
  #121
MDoherty97's Avatar
I read on a mustang forum "If you disconnect the brake light switch and the lights stay on then you have a short to power somewhere.... could be between 2 wires or in the turn signal switch. Could also be something wired incorrectly." What wires would cause this?
Old Oct 23, 2021 | 01:09 PM
  #122
Both "switches" are really sensors that send a signal to the BCM. The BCM then sends the appropriate signal to the appropriate device. Older cars they were actual switches that just turned the current on or off to a light.
First you say no brake lights now you say they won't go off.
Please get you stuff straight.
I suggest that you put everything back to the way you found it and take it to someone that has a clue.
Old Oct 23, 2021 | 01:11 PM
  #123
MDoherty97's Avatar
Originally Posted by donbrew
Both "switches" are really sensors that send a signal to the BCM. The BCM then sends the appropriate signal to the appropriate device. Older cars they were actual switches that just turned the current on or off to a light..
Ok so why won't the lights turn off? Something with the BCM? Because even disconnected, the sensor can't send a signal to the BCM
Old Oct 23, 2021 | 01:13 PM
  #124
MDoherty97's Avatar
What I thought was daytime running lights, the tail lights. Now putting the hatch down I can see the its the brake lights themselves. This is all new to me like I'm trying, and I explained in the post it was hard to describe. I had my sister standing at the back, this time I had my dad so now I have a clearer answer since doing the experiment with him. I can only get straight what I actually know
Old Oct 23, 2021 | 01:14 PM
  #125
MDoherty97's Avatar
The brake lights are always on unless I pull out the key. They only turn off when the key is taken out.
Old Oct 23, 2021 | 02:06 PM
  #126
What about the CenterHighMountedStopLight(CHMSL)?
Old Oct 23, 2021 | 03:24 PM
  #127
MDoherty97's Avatar
Thats in the fuse box right? I checked over all the fuses and relays again and swapped anything that seemed to affect the lights. I recall seeing that on one of the fuse/relay diagrams on the plastic covers. I think the brake lights are recent since touching the switches but I can't be certain if it is recent or has been a thing for a while unnoticed since I've been working in the front
Old Oct 23, 2021 | 04:05 PM
  #128
The stop lights that are mounted high in the center of the rear hatch.
Old Oct 24, 2021 | 11:25 AM
  #129
MDoherty97's Avatar
Yeah they're always on as well
Old Oct 24, 2021 | 11:34 AM
  #130
They are on different circuits so must be the switch/wires.
