HHr SS Electrical Problems Growing
Old Oct 26, 2021 | 10:00 AM
  #141
MDoherty97's Avatar
Just so we're on the same page:
The lights were on in the back, which you thought were tail lights, part of the DaytimeRunningLights(DRL). Stepping on the brake pedal didn't change the brightness of the lights, so you thought the brake lights didn't work.
Now you've realized that it was actually brake lights that were on all the time.
The DRLs do not illuminate the tail lights.
CORRECT yes except I realized that the brake bar was on too
Old Oct 26, 2021 | 10:01 AM
  #142
MDoherty97's Avatar
There's no stop light fuse in the underhood fuse block. You'll have to follow the wires from the sensor, through the firewall, and into the fuse block.
It might be interesting to pull the stop light fuse from the interior fuse block, see what happens.
Interesting thats what I was thinking and that could be a good idea
Old Oct 26, 2021 | 10:02 AM
  #143
MDoherty97's Avatar
The car is getting rolled out of the garage today, too much other stuff to do. So unfortunately I'll have to get back to it later and I'll post again then
Old Oct 26, 2021 | 11:13 AM
  #144
MDoherty97's Avatar
update: Just before we rolled the car I pulled the 10A stop lamp fuse that was mentioned. The brake bar light was no longer on, win; but the tail brake lights still were
Side note: Rolling the car there was no brake resistance, however what looked like and felt like (movement wise) the shifter in neutral, was actually first
Old Apr 14, 2022 | 02:05 PM
  #145
Father Azmodius's Avatar
Comm bus error
There are 9 control modules in my car and if there’s a com bus error while driving, the gauges do strange (or nothing at all) things, BUT, it keeps running. Once it’s shut off though, it will not restart. Your ESC light reminds me of one if the earliest times that happened to me and it left me stuck. I found out the RPD is in that lan network, and kept it from starting one time I had it unplugged.
Jakepilkntn
Sep 28, 2020 06:09 AM
Naz
Jul 3, 2020 06:50 AM
Bpopilek
Oct 6, 2019 03:23 PM
John Shalanda Williams
Dec 12, 2017 11:44 AM
cole81
Jan 27, 2016 01:25 PM
