I want to add an oil pressure gauge
Old Sep 3, 2024 | 04:51 PM
  #31
hhrumadbruh's Avatar
Originally Posted by donbrew
Oil pressure gauge does not have anything to do with oil volume, unless it is completely empty. I know this from blowing an engine up by cross threading the drain plug.
If the light is on when the key is on engine off the wires are good.
only comes on after the engine is warmed up- and even then, it goes off and on rapidly, almost seems like it's related to movement but not entirely.
Old Sep 3, 2024 | 05:28 PM
  #32
I still don't know why you you said that you checked the oil level by draining it. Is the dipstick missing?
Old Sep 3, 2024 | 06:31 PM
  #33
I have a hard time getting an accurate reading from it so I wanted to play it safe
Old Sep 3, 2024 | 08:01 PM
  #34
So, the oil light does not illuminate when the key is on and engine off? If the engine is off there is no oil pressure, the light should be on.
Old Sep 14, 2024 | 07:02 AM
  #35
unknwn's Avatar
Some folks just enjoy an array of analog gauges I'd venture.
For a street-able automobile though, an oil pressure circuit would be better served with a 'transducer'(?) sort of sending system, instead of a leak-prone plasti-line snaking into the cabin area.
What I'm suggesting is quite a bit more expensive, and the 'engine side' sensor/sending unit -is- sort of sizable, and would need to be remotely plumbed & mounted.
When you're working with an engine compartment as cramped as these, I'd advise sticking with a factory signaling light though.
Old Sep 14, 2024 | 07:49 AM
  #36
Like these ?
https://a.co/d/3RAkFnm
Old Sep 14, 2024 | 05:10 PM
  #37
unknwn's Avatar
That's the stuff
That sort of sending unit & gauge style tends to be quite accurate if you can get it adequately plumbed.
letterman7
Aug 1, 2021 10:05 PM
bassbase
Mods - Engine/Exhaust
24
Aug 23, 2020 04:20 PM
BZERKED
Aug 12, 2011 08:14 AM
havanetalking
Oct 7, 2008 07:15 AM
2K7 HHR
Aug 24, 2008 08:53 AM
