Improved mpg's for SS?
Old May 26, 2009 | 10:47 AM
Musicguy's Avatar
Considering chevy says 21/29 mpg you're already doing pretty well. I avg 27 usually with a mix of around town and highway at 75 ish mph. I don't stomp the pedal often. Besides it's an SS, not a maximum mpg barely get out of it's own way mobile. (not saying other HHR's are-just a general statement I've close to doubled the gas mileage of the truck it replaced with 4x the performance-I'm the guy from the land of happy now.
Old May 27, 2009 | 06:56 AM
mistermike's Avatar
Originally Posted by jerSSey HHR
My sweet spot is 60 MPH (32-34 MPG). At 65 MPH and up, the MPG goes down significantly (27-28 MPG).
That's pretty much my experience, too. These things aren't very aerodynamic.
Old May 27, 2009 | 08:56 AM
Canuck's Avatar
Originally Posted by GTOMIKE
Are you talking 30 to a U.S. gallon or an imperial gallon
We may not be talking about the same thing depending if he is referring to Imperial (Canadian) Gallons or US Gallons? Since he is probably converting from Litres to Gallons I'd assume it is US Gallons but that should be confirmed.
My best tank full (US Gallons) has been 31.6 (hwy, cruise control/downhill) and my worst (city, lead foot/uphill) was 22.8. If you haven't had an oil change yet (i.e. low mileage) you could expect some improvement. I experienced a noticeable improvement after a break-in period at about 10,000 km (6,000 miles)
Measurements were computed from the odomenter reading and actual gasoline used. I found the DIC (on my vehicle) slightly inflated my numbers.
Old May 28, 2009 | 07:53 AM
jerSSey HHR's Avatar
Originally Posted by VictorySpeedway
I have a feeling this will improve when the engine loosens up a bit.
Let's hope it doesn't loosen up too much.
Old May 28, 2009 | 08:10 AM
hyperv6's Avatar
I figure when my engine lossens up I will have to remove gas out of the tank since I will not be able to use all the gas I am saving! LOL!!!!
FBR_User
Sep 9, 2014 10:34 PM
Silverfox
Nov 2, 2013 04:31 PM
TkHHR
Jan 7, 2008 03:39 PM
greyghost
Dec 31, 2006 03:32 PM
