Launch Control Mode - RPM
Old Nov 21, 2009 | 11:42 AM
XXL's Avatar
XXL
Originally Posted by hyperv6
That is correct. the stock converter stalls at a much lower RPM.
Not most new GM cars are limited in netral today. You can stand on the gas and only go to 4100 RPM. GM has a built in rev limiter that changes in gear. I am not sure but have seen this on several throttle by wire systems. They all seem to have it.
All driven by table data in the ECM. If you look in HPT, they have uncovered this table... and RPM limit can be set for any gear, including Neutral. Good for limiting slip on hard 1st gear launches (and saving axles!), as well as if you turn them WAY down when the car goes into service where cars are often abused (I'm thinking of the myriad body shop stories where the emplyees are drag racing customer cars behind the building). Turning every gear down to 2500 RPM ensures they'll have a nice and piggy car to drive, that is still capable of actually getting on the highway if needed for legitimate reasons. Or, if you've discussed vehicle movement with the shop and they have ensured that it won't need to be moved more than from bay to bay, turning every gear down to 1500 RPM adds a little "trust but verify" factor.
Jac432
Mar 28, 2011 08:07 PM
chevyss
Nov 30, 2010 07:46 AM
gmdealerguy
13
Feb 3, 2010 06:40 PM
FastedSS
Apr 1, 2008 07:42 AM
turbofreak
Feb 20, 2008 03:15 PM
