Low oil pressure??!!
Old Dec 13, 2017 | 08:58 PM
Livininfast4ward's Avatar
I have checked my oil pressure in my car, I have an aftermarket meter i have installed and it started reading under 15psi at idle, used to be around 50psi I used a proper pressure meter and got the same reading. I haven't gotten a low oil pressure light on the dash. Only mods to the car are injectors, ignition, holset hx35 turbo upgrade, and high pressure fuel pump/lines what should be the first thing to check?
Old Dec 13, 2017 | 09:06 PM
I would think the first thing to check would be the oil level.
Old Dec 13, 2017 | 09:09 PM
levels are good, I'm trying to find a diagram or something that displays the components of the oil system, parts that have been replaced are cam phasers and timing chain system
Old Dec 13, 2017 | 09:14 PM
The oil pump is set into the timing cover. I seem to remember someone putting theirs back together, only to find low oil pressure. Somehow the pump got damaged.
Old Dec 13, 2017 | 09:19 PM
I'm curious why my pressure light hasn't shown up on the dashboard at 15 psi should that thing be derating my motor
Old Dec 13, 2017 | 09:22 PM
You might also inspect the oil filter, see if it's clogged or crushed enough to impede flow.
Wait, where are you checking the pressure? I seem to remember talk of locations in the head and in the block. One is the incorrect location and gives a much lower reading.
Old Dec 13, 2017 | 09:24 PM
towards the top of the motor can't remember if it was on the block or in the head honestly it's been a few momths since I checked, but I've been going through timing chains and oil pressure seems to be the culprit
Check my edit above
EDIT Again: Now the other edit isn't showing, here it is again https://www.chevyhhr.net/forums/prob...74/#post819719
I see I had put it in the wrong post before, oops!
Old Dec 13, 2017 | 09:45 PM
Change out the oil pump, if you’re chewing up timing chains. I’ve trusted Melling oil pumps for decades.
http://www.ebay.ca/itm/MELLING-K349-...-/302148070993
Old Dec 13, 2017 | 09:46 PM
I'm just worried that I may have spent a bearing, it idles cold around 20psi and warms up drops to 15psi I don't want to go replacing parts if I should just replace the motor
