Low oil pressure??!!
idk much about these motors but can you physically replace the bearings and be fine or does it require to be rebuilt
If you spun a bearing you need to machine the journal to clean up any bearing surface damage. To keep balance, I usually turn all four rod bearings.
It’s a pull the engine event, and take it to a machine shop .
yea I've done it on a crown vic but that was a much simpler task this motor is a ***** to pull out
JAXFL_SS
12
Apr 5, 2012 08:22 AM
