Low oil pressure??!!
Old Dec 13, 2017 | 09:51 PM
True , drop the oil pan and remove one main bearing cap at a time , then one rod bearing at a time . Why spend money on a new engine if it’s just a weak pun spring.
Old Dec 13, 2017 | 09:52 PM
Livininfast4ward's Avatar
idk much about these motors but can you physically replace the bearings and be fine or does it require to be rebuilt
Old Dec 13, 2017 | 09:58 PM
If you spun a bearing you need to machine the journal to clean up any bearing surface damage. To keep balance, I usually turn all four rod bearings.
It’s a pull the engine event, and take it to a machine shop .
Old Dec 13, 2017 | 10:00 PM
yea I've done it on a crown vic but that was a much simpler task this motor is a ***** to pull out
Old Dec 13, 2017 | 10:02 PM
Not really, it can be hoisted out the top! It’s just a tad tight!
alfolsee2000
May 30, 2016 08:23 AM
Jfidelh
Oct 9, 2012 06:14 AM
JAXFL_SS
12
Apr 5, 2012 08:22 AM
DSNYCRZE
Jan 6, 2011 11:21 PM
