Metal grinding noise while driving
Old Sep 12, 2021 | 10:34 PM
Fedves86's Avatar
Hey guys I was recently gifted the 2009 HHR SS and as soon as I put it into drive and the vehicle starts moving I hear a scraping sound almost like how the brake pads are worn down when you're driving and you hit the brakes and you're grinding the rotors sousnds like that I did find a sticky driver side front caliper but the the sound is coming from all four tires still, does anybody have any idea what this could be? I've taken it to quite a few mechanically inclined people and none of them could figure it out either
Old Sep 12, 2021 | 10:45 PM
Bad hubs.
Old Sep 13, 2021 | 05:37 AM
If the SS has been sitting , yes bad hubs! Corrosion on the brake rotors will also cause the noise but should be obvious.
Old Sep 13, 2021 | 01:26 PM
thirdgenz28's Avatar
Yes if it's been sitting for a while and has been raining or damp out it does not take long for the pads to leave some pretty healthy rust patches on the rotors.
Old Sep 13, 2021 | 02:37 PM
Especially semi metallic or metallic pads.
Old Sep 13, 2021 | 07:36 PM
Ditto..
Old Sep 14, 2021 | 03:46 AM
Fedves86's Avatar
I just changed all the hubs so maybe rotors
I do have another cause/question, the triangular spacer between the hubs and knuckle, if I'm looking at the hub which way is the tab supposed to be oriented? Seems the way they are the tabs are very close into the rotors, passenger front looks like it had been scraping the rotor as well so I bent it back a little, I ask because the gentleman that had the car before me.said he'd just had the brakes done before he had to park it, and I found out the other day the 7 months he said it was sitting was closer to 2 years 😅
Old Sep 14, 2021 | 07:17 AM
That tab covers the wire for the ABS over the larger opening of the steering knuckle
You see it here over the tie rod area of the steering knuckle pointing towards 1 to 2 o’clock
Old Sep 14, 2021 | 08:01 PM
Old Sep 16, 2021 | 12:23 AM
Fedves86's Avatar
Unless there are different versions of that spacer I have something else on mine, it is literally flat, it would lay flat on the ground, there is just a square area that juts out of one side. If you guys havent heard of that before I'll take a hub off and take a picture.
