MPG and tire PSI plunging with temperature
Old Dec 25, 2008 | 02:57 PM
  #31
mistermike's Avatar
Originally Posted by JoeR
PV = nRT... Look it up.... educate yourselves and report back.
You didn't get the memo that nitrogen was granted a special exemption from the Ideal Gas Law by the company that sells those nitrogen inflators to service shops? I'm sticking with Helium because the lighter weight improves my fuel economy.
Old Dec 25, 2008 | 03:04 PM
  #32
JoeR's Avatar
Well, just maybe, that nitrogen is a "special formulation" that is exempt.
Hey, I use helium also!! Makes the car lighter and we all (should) know that a lighter car is faster!!
Seriously, not trying to give any particular person a hard time, but it's to everyone's benefit here to know what works and what is marketing BS, myth and lore contrived to empty your wallet (with the acknowledgement that your car will also be "somewhat" faster with a lighter wallet!!).
Old Dec 25, 2008 | 04:03 PM
  #33
Freightliner's Avatar
The reason your MPG drops in the winter is the gas "winter" blend. I forgot off the top of my head what they put in the gas but it lowers the BTU's of the gas a bit over the summer blend.
Also, this time of year your warm up your car a bit? The heater fan is on, lights are on more, etc. this all adds up to lower MPG.
And yeah, keep your tires inflated!
Old Dec 25, 2008 | 04:05 PM
  #34
hyperv6's Avatar
Generally Nitrogen has less increase in pressure form what read since it is a dry air and has no moisture in it vs normal compressed air. The moisture has more to to with expantion than anything. Pit crews run on Nitrogen too to keep the moisture out of the air guns.
Note the moisture you get out of your compressor in the garage and have to drain when your done.
I still don't see the point as 1-3 pounds is not goinmg to make a differance in normal driving.
Now you might want to add a 1/2 pound of nitrogen in Turn 2 at Darlington if the car is too tight coming off the corner. But I have not seen to may HHR SS in the race there. LoL.
Old Dec 25, 2008 | 04:51 PM
  #35
Chevy SS's Avatar
I would like to fill mine with Nitrogen... maybe next time I get tires or switch wheels.
Old Dec 25, 2008 | 06:23 PM
  #36
XXL's Avatar
XXL
Originally Posted by ChevyMgr
Anywhere from $20 to $60 if you drive in and want it done.
All to squeeze out that pesky 21% oxygen. PT Barnum was right.
Old Dec 25, 2008 | 09:34 PM
  #37
hyperv6's Avatar
I also have the hide from a Spam animal for sales too.
Old Dec 26, 2008 | 08:55 AM
  #38
jerSSey HHR's Avatar
That was a good point that you would have to evacuate the entire tire of air in order to fill back up with nitrogen. I doubt they would do that.
Old Dec 26, 2008 | 08:58 AM
  #39
gcsd3742's Avatar
Um thats how mine were done....And lady3bglover's as well
Old Dec 26, 2008 | 09:02 AM
  #40
They actually sucked all the air out of the tires?
