MPG and tire PSI plunging with temperature
Old Dec 27, 2008 | 07:47 AM
  #51
millerrdjr's Avatar
Nitrogen IS better for passenger tires, especially if you don't have to pay for it.
Old Dec 27, 2008 | 07:59 AM
  #52
The Curly 1's Avatar
A few things to note
"Nitrogen molecules are less likely to escape from the inside of a tire compared with the traditional air mixture used. Air consists mostly of nitrogen and oxygen. Nitrogen molecules have a larger effective diameter than oxygen molecules and therefore diffuse through porous substances more slowly.[11]"
Just like Helium leaks out of a balloon much faster than air so that makes a little sense.
Still that differense is minimal as there is only 21% Oxygen in the air we breathe.
When they remove the Oxygen from the Nitrogen they also remove the moisture. Yes, probably could hold moisture but there is very little if any in the the nitrogen you buy.
I do not think air pressure is the main cause of the OP's mileage drop. Just air up the tires and see what happens and I do not think putting pure nitrogen in it will save the world or make much difference.
Old Dec 27, 2008 | 08:20 AM
  #53
catdaddy137's Avatar
do you know where
we can get it for free?
Old Dec 27, 2008 | 09:11 AM
  #54
millerrdjr's Avatar
Try this site, scroll down and enter your zip code.
Some are free, some aren't.
http://www.getnitrogen.org/
Old Dec 27, 2008 | 07:02 PM
  #55
LT1GMC's Avatar
Originally Posted by JoeR
Sorry... YOU FAIL!!
Nitrogen is NOT one of the inert gases.
Water vapor (moisture) certainly can be present in nitrogen.
Water vapor acts just like the other gases and follows the gas laws.
Under the high temps encountered in racing, water vapor "can" become steam, which expands considerably in that state.
As for passenger cars, we agree.
Nitrogen is not a "noble gas" but is considered INERT because it is non-reactive, and does not easily hold water. It is listed as an inert gas by NASA, and many gas suppliers. Check this MSDS sheet's definition:
http://www.ilpi.com/msds/ref/inert.html
You also obviously don't remember much of your chemistry if you believe water vapor follows the gas laws.
Old Dec 27, 2008 | 08:17 PM
  #56
hyperv6's Avatar
THis is all true!
Old Dec 27, 2008 | 10:03 PM
  #57
gcsd3742's Avatar
Well got mine refilled today after I got a faulty TPMS replaced....
Old Dec 28, 2008 | 05:17 AM
  #58
Old Lar's Avatar
Air is 80% nitrogen already. I got, in the mail, an ad for refill with nitrogen, and they wanted $20/tire for a refill. What do you do on the road and no nitrogen refill station is at your gas fuel stop... you use regular air to inflate the tire.
From the link, I do see a tire store close by that does do fill with nitrogen. Maybe when I get new tires I'll go there.
Old Dec 28, 2008 | 02:58 PM
  #59
hyperv6's Avatar
Hey, I heard if you use Nitrogen in your tires it removes all your money problems. No money=No problems.
Use it if you want but I have better things to do with my money.
Nitrogen is nothing but a money maker a money maker for dealers and tire store.
Google the topic and they all say the same thing. There is nothing wrong with it and there are some very minimal advantages but in the end your better off checking your air pressure once in a while and using the money to buy a small compressor from Walmart.
Here is a good example of what most of the informed experts say:
Oh, there are plenty of benefits: (1) Cool fluorescent green valve stem caps (assuming your nitrogen vendor has any marketing savvy), which will look sharp with your spinning wheel covers. (2) Bragging rights. OK, you were behind the curve with cell phones, iPods, thong underwear, etc. Nitrogen in tires is relatively new to the mass market. Now's your chance. (3) Reduced fire danger next time you land your space shuttle or commercial aircraft, and tell me you won't sleep better knowing that.
Most tires are filled with compressed air, which when dry consists of about 78 percent nitrogen, 21 percent oxygen, and 1 percent other gases by volume. Water vapor (humidity) can make up as much as 5 percent of the volume of air under worst-case conditions. Filling your tires with nitrogen mainly does two things: it eliminates moisture, and it replaces skinny oxygen molecules with fat nitrogen molecules, reducing the rate at which compressed gas diffuses through porous tire walls. That means, theoretically at least, that a tire filled with nitrogen retains optimal pressure longer, leading to more uniform tire wear and better gas mileage. The commonly quoted figure is that tires inflated to 32 psi get 3 percent better mileage than at 24 psi.
Does nitrogen make any practical difference? You couldn't prove it by me. I found no scientific tests showing that nitrogen-filled tires stayed inflated longer than average under normal conditions. A car-buff buddy was sure it worked but conceded he had only anecdotal evidence that it did.
As for moisture, changes in humidity affect tire performance two ways. First, the density of humid air fluctuates more with temperature than that of dry air, so removing humidity can keep your tire pressure more consistent, especially when the temperature climbs over 100 degrees Fahrenheit. That may be a legitimate concern in Formula One racing, but it's not much of an issue if you're just tooling around town.
Humidity can also be a factor in wheel maintenance - since pure nitrogen doesn't have moisture in it, supposedly your wheels won't rust as quickly, which could lead to improved wheel performance and air sealing. The question is, how big a problem is wheel rust these days? According to a few tire and wheel shops we contacted, not very. Seriously rusted wheels are uncommon in typical steel-wheeled cars, and many high-performance cars have alloy wheels that don't rust at all. One exception is work vehicles such as dump trucks, which are exposed to a much harsher environment.
Another claim I've seen is that since nitrogen is slightly lighter than air, you'll save weight and get better performance. However, we're talking about a weight difference of less than 4 percent of the gas in the tire - in other words, a difference of less than an ounce for most vehicles. A possibly more realistic benefit is that nitrogen is largely inert chemically at low (i.e., normal) temperatures, so it won't attack the rubber in your tires like oxygen does. Oxygen attack is something both the National Highway Traffic Safety Administration and Ford Research have studied, and can be a problem for tires used for a long time or in rough conditions.
More important, nitrogen doesn't support combustion, which is one reason aircraft and the space shuttle use nitrogen in their tires. The wisdom of this precaution was brought home by the crash of Mexicana Airlines flight 940 on March 31, 1986. Shortly after the Boeing 727 took off from Mexico City en route to Puerto Vallarta, an overheated landing-gear brake caused a tire improperly filled with air instead of nitrogen to overheat as well and explode, rupturing fuel and hydraulic lines. The ensuing fire and crash killed 167 passengers and crew. However, unless your driving habits are of the X-treme variety, the chances of your tires catching fire anytime soon are slim.
Overall, filling up with nitrogen won't hurt and may provide some minimal benefit. Is it worth it? If you go to some place like Costco that does it for free with new tires, sure, why not? Elsewhere, though, I've seen prices quoted as high as $10 per tire, which is way more than I'd pay. Rather than shell out for nitrogen, you'd be better off just checking and adjusting your tire pressure regularly, something the NHTSA says less than 60 percent of U.S. motorists actually do.
Note in one test by Consumer Reports they side over a period of time expect the air loss vs Nitrogen loss to be 3.5 pounds vs 2.5.
So do yourself a favore and just buy a small compressor, check your tires and use the compresosr to fill your kids blow up pool with it. You might just extend your life more this way and save a lot more on hospital bills.
Old Dec 29, 2008 | 08:20 AM
  #60
jerSSey HHR's Avatar
I think I'm going to try filling up my tires with hydrogen next time. That should lend itself to some explosive starts off the line.
