MPG and tire PSI plunging with temperature
Not if you use antifreeze air.
Also make sure when you rotate the tires you use the correct direction Nitrogen. Left side Nitrogen or right side must be in the correct tires.
Liquid Nitrogen is fun to play with. We had where I worked and we had to dump it out once in a while. We would freeze different things for fun. I once froze my shoes to the ground in August once when I spilled some.
Buy some giant ZipLoc bags and do the work inside. Make sure there's someone around to unzip the bag and let you out when you're done... and hurry. While Nitrogen is 78% of the air we breath, it's the 21% oxygen that your blood vessels need to shuttle around the body.
cj krause
Tires & Wheels
Aug 3, 2006 06:46 PM
