MPG and tire PSI plunging with temperature
Old Dec 29, 2008 | 09:44 AM
  #61
ChevyMgr's Avatar
Originally Posted by jerSSey HHR
I think I'm going to try filling up my tires with hydrogen next time. That should lend itself to some explosive starts off the line.
If you use helium your horn sounds like a sick goose when you honk it.
Old Dec 29, 2008 | 10:03 AM
  #62
catdaddy137's Avatar
Smile Great!!!
love that new avatar too
Old Dec 29, 2008 | 10:10 AM
  #63
hyperv6's Avatar
No you get better handling and more MPG. The Helium gives you less unsprung weight as your wheel and tires become weightless.
Old Dec 29, 2008 | 10:16 AM
  #64
Cokeybill's Avatar
When I change my winter tires for the summer tires, can I save the Nitrogen from the winter tires for use in the summer tires
Probably possible but expensive.
Old Dec 29, 2008 | 11:11 AM
  #65
Arne73's Avatar
....I've got factory air in my SS!
Old Dec 29, 2008 | 11:14 AM
  #66
tomw's Avatar
Yes but you need to change your summer air to winter air
Old Dec 29, 2008 | 12:31 PM
  #67
hyperv6's Avatar
Not if you use antifreeze air.
Also make sure when you rotate the tires you use the correct direction Nitrogen. Left side Nitrogen or right side must be in the correct tires.
Liquid Nitrogen is fun to play with. We had where I worked and we had to dump it out once in a while. We would freeze different things for fun. I once froze my shoes to the ground in August once when I spilled some.
Old Dec 29, 2008 | 12:50 PM
  #68
XXL's Avatar
XXL
Buy some giant ZipLoc bags and do the work inside. Make sure there's someone around to unzip the bag and let you out when you're done... and hurry. While Nitrogen is 78% of the air we breath, it's the 21% oxygen that your blood vessels need to shuttle around the body.
Old Dec 29, 2008 | 01:13 PM
  #69
jerSSey HHR's Avatar
Way to go green!
Old Dec 29, 2008 | 01:14 PM
  #70
Yeah - don't want to hear about some do-it-yourselfer getting the bends!
fastED
Feb 11, 2025 07:14 AM
sammyrye
Mar 1, 2015 01:07 AM
Restlessone
Jan 1, 2015 06:35 PM
budzone
Jan 23, 2009 09:50 PM
cj krause
Tires & Wheels
Aug 3, 2006 06:46 PM
