My '08 HHR SS just turned....
Old Jun 5, 2018 | 10:30 PM
Cokeybill's Avatar
40K and is my DD. GM tune still strong. New brakes, new battery and new rubber is all that's been required to change so far. Of course all maintenance was performed in a timely manners. Not a bit of rust and body has no dents(disabled parking spots saved it). I bought this in Feb/08 with my GM discount and I'm struggling to sell it and get a '19 Caddy XT5 or keep it and get an '19 XT5. Any way I'm going to look how GM improved the XT5 compared to the '18 model. I think the front end looks like the new Chevy front ends. Irks me a bit.
Old Jun 5, 2018 | 10:46 PM
Congrats on hitting 40K,
And happy hunting..
Old Jun 6, 2018 | 08:20 AM
Keep the SS, it’s hard to find a replacement, cause you will miss it!!
Post pictures of the XT5.
Old Jun 14, 2018 | 10:59 AM
SuperSam's Avatar
I agree with Oldblue. Keep the HHR SS.
Old Aug 8, 2018 | 11:55 PM
BlackSS200k's Avatar
214k on the SS and the turbo went out today. Fix or dispose?
Old Aug 9, 2018 | 07:47 AM
Replace the turbo, if course!
Cat Man HHR's Avatar
If you like the car, fix the turbo. Have you done the chains? Have you kept up with oil changes?
Old Aug 9, 2018 | 07:56 AM
Yes, yes, yes. After it screeched I drove about 5 miles with no power and no CEL. Started looking at it and it’s a quart low. I must of burnt up some oil when it went,
Old Aug 9, 2018 | 12:24 PM
More than likely went out the exhaust. Worked on turbo engines a lot (Caterpillar stuff) and have seen failures, some really bad.
Cat Man name (Caterpillar)
Old Aug 11, 2018 | 07:32 PM
Well, I changed the turbo today, everything went well until. I put it all back together and started it, then I heard a spraying sound. I never tightened the top banjo bolt on the turbo. Either the return or the feed line? Well, it idled out about 3.5 quarts of oil on to the floor, in about 25 seconds maybe less. Anyway, tighten that up, took for a test drive after changing what was left of the oil. The car ran better than it has for a years. Brought it home and cleaned the oil off with simple green and a garden hose. Drove the car to gas station, and guess what? No more boost? What went wrong? Took the intake and exhaust off the turbo, it’s all clean the turbo still spins and feels tight, didn’t make any noises like my old one when it failed. Could the water have done something? I let it cool for a while, it wasnt hot to the touch. I don’t have a clue how to diagnose this, but I can get it back out of the car in 45 minutes max! Cleaned all of the bolts and used anti-seize on them!
C.riv154
Jan 20, 2018 01:57 PM
Oldblue
Feb 17, 2017 07:13 PM
ymerej_mortsdnil
Jun 4, 2013 01:29 PM
OCMerrill
Nov 19, 2008 09:36 PM
Lone Ranger
Jun 1, 2007 12:38 PM
