SS Hood Insulation Question
Old May 15, 2009 | 05:50 AM
  #91
hyperv6's Avatar
Originally Posted by shaginwgn
Was also a fit issue according to GM Performance engineer. I asked at a Cobalt Meet during a Cobalt SS presentation.
Yep! Your intake box if your hood is adjusted properly will be right against the hood. It may rub.
Old May 15, 2009 | 06:27 AM
  #92
Canuck's Avatar
Originally Posted by hyperv6
Chevy leaves off the pad for a reason. Remember how hot Turbo's get and under hood compartments can get if you keep in the heat.
In reading the posts from the link provided I saw a lot of different (and some strong) opinions on the question of heat soak, use of the insulation for sound deadening, a suggestion that it is valuable as a fire retardant, and one (possibly informed?) opinion below:
The reason there is no hoodliner in hhr ss or the new cobalt ss is due to fitting issues with air box and such. This comes from a GM Performance Enigineer. Chadpuska and me asked at the ecotech meet when I noticed there was no hoodliner on the new cobalt ss.
Who knows for sure and I hope I haven't opened that can of worms back up. Maybe we should merge this post into the original and let it RIP?
Old May 15, 2009 | 06:35 AM
  #93
Canuck's Avatar
Oops I see I was late in posting the same message. Should have spend more time reading and refrain from stopping for a coffee in the middle of my postings (or learn to type faster).
Old May 17, 2009 | 07:49 PM
  #94
87silver's Avatar
I bought my HHR SS as a preowned vehicle and it came with hood insulation. Don't know why it's there or if it was a mistake at the factory or an add on by the previous owner. After reviewing some of the opinions from all of the knowledgeable and informed members, I became concerned.
As someone who deals with thermodynamics on a daily basis at my occupation, I ruled out the issue with heat containment/dissipation/transfer properties, but considered the possibility of sound resonance. But this is based upon my own experiences in the field and others are certainly welcome to their theories.
My concern was stress or chafing on the airbox, although I see no indication of it on the insulation or airbox at present.
As a static test, I placed pieces of painter's tape glue side up on all 4 top corners of the airbox and slowly but firmly closed the hood. Upon opening it, the tape was still on the airbox, undisturbed. I then tried the same test using some of my kid's modeling clay substitute, keeping the blobs relatively flat sticking to the top corners of the airbox again. Upon opening the hood, there was no evidence of contact. Maybe if I can get my hands on more of this stuff, I can determine what the approximate distance actually is. I'll follow up.
I got to thinking about what other vehicles with similar powerplants have in regard to the use (or lack of) hood insulation, so I checked pics on various websites. I posted the sites, but you would have to dig a little to see the pics that you want. I came to this conclusion:
The Pontiac Solstice is equipped with hood insulation
The Saturn Sky is equipped with hood insulation
The Cobalt SS is equipped with hood insulation
http://www.solsticeforum.com/photopost/
http://www.skyroadster.com/photopost/
http://cobaltss.net/gallery/
http://www.autoblog.com/photos/em-20...-turbo/460578/
It is my hypothesis that the most plausible theory is that of sound enhancement and possibly cost savings. In my opinion, I would not remove it if you have hood insulation, but I wouldn't add it if you don't.
Old May 18, 2009 | 07:56 AM
  #95
Canuck's Avatar
Very nice analysis and nice logical conclusions. My only issue with cost savings is they eliminated it for the SS model only. If they REALLY wanted to save money they would have done it across the line not just on the relatively limited production SS. My guess from your work then is sound enhancement which you stated as the primary reason.
Old May 18, 2009 | 08:20 AM
  #96
hyperv6's Avatar
The bottom line is it is not factory for a reason and if the benifits out weight the issues GM would have put it on.
Some times it is a very simple reason but still a reason.
Old May 18, 2009 | 11:19 AM
  #97
catdaddy137's Avatar
hmmm
whatever....and more points to ponder....what is the big peices of insulation for that are stuffed in the rear of the front fenders ??? i hope they don't hold moister/water.....would they be there for the same reason that there is , or is not insulation under the hood ???
Old May 18, 2009 | 12:00 PM
  #98
hyperv6's Avatar
Often these pads are to prevent heat and noise mostly noise. THey are water resistant.
Old May 18, 2009 | 12:02 PM
  #99
hyperv6's Avatar
Might note the air box is different on the HHR and is close to the hood. THis may be why we don't get the padding. All the other LNF engines have different air boxes.
Old May 20, 2009 | 07:37 PM
  #100
Lee3333's Avatar
The new Mustang has a sound tube (or something like that) which connects the engine compartment to the passanger area so you can hear the motor louder. So it is conceivable that Chevy assumed people buying the SS would like to hear engine sound.
That said, I removed my liner several years ago. First, I show the car and it looks much better without it. Second, I prefer not to trap the heat under the hood. Third, even though it is only 3 pounds, it is positioned pretty high above the wheels which certainly wouldnt help the handling. Sure, it may be petty, but a pound here and a pound there...
87silver
"How To" Tutorial Library
12
Mar 30, 2014 09:27 AM
bunz315
Maintenance and Upkeep
7
Apr 9, 2013 06:43 PM
SSROADSTER
Aug 6, 2012 01:28 AM
jbman
7
Oct 6, 2009 02:47 PM
RUDEINC
Oct 30, 2006 12:15 AM
