SS Hood Insulation Question
Old May 18, 2008 | 05:36 PM
  #61
Razinhell's Avatar
Originally Posted by white heat
Why make the intercooler work harder by trapping more heat under the hood?
I doubt it would trap the heat by lining the hood, but again this would probably be something we would need to see in a wind tunnel to see how the air flows past the engine bay. I also seriously doubt any hood for any car would cause any more heat soak, while driving, then the engine already produces. Now if your standing still and want to cool the system then just open the hood. Also Intercoolers don't work harder as all they are only big radiators. No mechanical parts and since they sit before the entire engine bay they also will have zero effect from heat soak as long as the car is not sitting still.
Old May 18, 2008 | 10:08 PM
  #62
sanddragger28's Avatar
Originally Posted by XXL
An intercooler doesn't cool the engine. It cools the air charge coming _out of_ the turbo.
Take that intercooler off and see if that engine dosent run a lot harder and has a lot less power.
Old May 18, 2008 | 10:13 PM
  #63
Originally Posted by SSROADSTER
Not having a vast knowledge of Turbos (or anything for that matter ),
my question is; the colder the air gets through the intercooler, would be more likely to produce more power, correct? If that is the case, if there was something else added to the intercooler area to cool the air even more so, then you would really see an increase in power? The reason being, a friend had mentioned some type of device that was out years ago, which cools the air through the intercooler, with nothing needed to do to the engine. He is in the process of getting me this info. Just found it interesting
Some people spray the intercooler with alcohol and another common method is Nitrous which works really well. Water will work but not to the degree of the others. Ive seen people at race tracks spary the Intercooler with Alcohol in a spray bottle before each pass. A really big new front mount intercooler will even make a big difference. Im sure theyll be on the market for the SS soon if not already.
Old May 19, 2008 | 09:52 AM
  #64
LT1GMC's Avatar
If noise is more important than performance, go for it. However, if you don't mind sounding like a delivery truck at idle, you'll be better off without the extra 40# under the hood. Or... if you're like me, you could stand to lose 40# yourself, which would mean you could have both
I believe the hoodliner weighs 3# at the most, its just a piece of fiberglass insulation, so I'll just skip lunch to make up for it. :)
Old May 19, 2008 | 07:45 PM
  #65
XXL's Avatar
XXL
Good point. I was thinking in terms of the Dynamat-style hood liner products... butyl rubber and tar paper layering, not the fuzzy fiberglass one that GM has been stuffing under hoods for decades. I guess this means I can have another snack as well.
Old May 19, 2008 | 08:10 PM
  #66
ChevyMgr's Avatar
Does anyone know that the GM hoodliner is made so that if there is an engine fire, the tabs quickly melt off, and the therory is, that the hoodliner will fall off the hood and help to smother the fire out? Just a tidbit I thought I would add to this thread.
Old May 19, 2008 | 08:14 PM
  #67
ivtech's Avatar
I have what maybe a stupid qestion is that hoodliner listed under SS parts. When I was at the dealership asking about a part they wanted my VIN to make sure they had the right part #.
Old May 19, 2008 | 09:14 PM
  #68
SSROADSTER's Avatar
fan test tongiht....
Originally Posted by c2vette
I was kind of surprised that the fans do not continue running for a while after you shut off the motor. A lot of cars will do this to reduce heat soak (including our BMW), and I would think the turbo would benefit from this. It is 100 deg here right now, so can't say that it hasn't been hot enough to activate it.
before I pulled in the garage, I let the SS sit in the driveway in D, and watched the temp in the DIC. went up to 210 degrees and the fan came on, the temp just stayed there, did not drop. but at least it came on at 210, if I remember correctly , my SSR fan did not come on til about 220 or 226, (can't remember), ended up getting an aux fan for that , which worked great.
further testing is needed......
Old May 19, 2008 | 09:19 PM
  #69
SSROADSTER's Avatar
found this info on another forum, www.snowperformance.net
one guy with an SS is going to try it, should be interesting to say the least
Old May 19, 2008 | 09:30 PM
  #70
ChevyMgr's Avatar
No, and not under your VIN either. They will actually have to go old school and look it up. These days you enter the VIN and the system knows how your car was built and looks up the correct part number. Well, most of the time.
P.S. the only stupid question is one not asked...
Last edited by ChevyMgr; May 19, 2008 at 09:31 PM. Reason: added my words of wisdom for today
