Are SS transmissions different?
Old 02-20-2019, 12:42 PM
wokbelly's Avatar
Unhappy Are SS transmissions different?
Hi guys i got a SS HHR with a bad manual transmission looking for a replacement are these compatible with other HHR manual transmissions or do you have to replace them with an SS transmission? Thanks
wokbelly is offline
Old 02-20-2019, 03:19 PM
Cat Man HHR's Avatar
I found this:
https://en.wikipedia.org/wiki/F35_transmission
Final gear ratio is the main factor. Gearing in the the trans is all the same ratio.
Cat Man HHR is offline
Old 02-20-2019, 03:23 PM
Is F35 the differential?
Oldblue is offline
Old 02-20-2019, 06:08 PM
Blue_SS's Avatar
No. F35 is the trans. There's an error in the wiki.
Saab developed it. GM's FWD Manual Trans efforts were non-existent. This was a "use the Saab one or buy one" decision for the SS.
Blue_SS is offline
Old 02-20-2019, 06:09 PM
Blue_SS's Avatar
For posterity....
Blue_SS is offline
Old 02-20-2019, 06:18 PM
The same link from Cat Man
Oldblue is offline
Old 02-20-2019, 06:55 PM
Yes, they are different.
The SS uses the Saab F35 (RPO code MU3 in the glovebox )
The LS, LT's use the Getrag F23 (RPO code M86 in the glovebox )
Those 2 transmissions will not be a direct interchange. You will need to find a Saab F35 to replace it with.
firemangeorge is offline
Old 02-20-2019, 09:20 PM
wokbelly's Avatar
So a Saab transmission is in these so i could use one from a Saab vehicle as long as the ones on the list are used and they should bolt up as long as it is an F35?
wokbelly is offline
Old 02-20-2019, 09:26 PM
wokbelly's Avatar
I just realized mines a 2008 so mine may be a different number and not an F35?
wokbelly is offline
Old 02-21-2019, 07:36 AM
It shows on the list 2008 to 2010 HHR SS used the F35
Oldblue is offline
Quick Reply: Are SS transmissions different?
