Stupid Question - Turbo PSI
Old May 6, 2011 | 10:19 PM
Sidecardog1's Avatar
Congrats on the new SS. The way the display on the top of the dash works took me a while to figure out until I read the manual! If you simply rotate (twist) the knob without pushing it in you will change the display on the left side of the screen. One of the choices will be the boost gauge among the others indicated in other responses. If you push the knob in first and let it up, then when you twist it you will scroll through the available displays for the right side of the screen. I find the digital speed indication helpful when riding through local speed trap areas where you need to be really aware of how fast you are going. The turbo gauge with the shift light tree combined with the competitive mode is for having a good time. I also have the 2010 and it apparently is the first year for this user configurable display and unfortunately also the last year for the SS. I especially like the ability to get the four wheel graphic up with the tire pressures as compared to scrolling through a bunch of stuff on the DIC before you get the pressures on that. Good luck with the new wheels.
Last edited by Sidecardog1; May 7, 2011 at 06:10 AM. Reason: additional info added
Old May 7, 2011 | 06:51 AM
Devils950003's Avatar
2009 was the first year for the RPD (as an option)...2010 was the first and only year that it became standard issue for SSes (I'm guessing to get red of as much RDP inventory as possible). The '08s had the A-pillar boost gauge.
Old May 8, 2011 | 01:42 PM
ChevyGuySS's Avatar
i was playing with one of those screens on a 2010 and i got to the boost and speed, i think you just have to mess around with it some more
Old May 11, 2011 | 08:38 AM
JPerrydore's Avatar
Just turn the knob and it will scroll through the different screens.Ex: Boost,cam angle,engine power etc etc. If you push the knob first then turn,it will change the current screens set up.Ex: battery volts,tire psi,inlet temp,gear selected etc.
I figured it out over the weekend, thanks!
Old May 11, 2011 | 11:39 AM
LewiSS's Avatar
I have a '10 with the RPD. I'd really like to get the stock pillar-mounted mechanical boost gauge so I can use some of the other features in the RPD and still have a full-time boost gauge. Just haven't gotten around to picking one up salvage yet.
thegodfather
Jun 28, 2011 06:37 AM
bully219
Maintenance and Upkeep
20
Feb 16, 2011 02:01 PM
saltyfishguy
Aug 21, 2009 02:47 PM
HipHotRod
2.4L Performance Tech
Apr 4, 2008 04:02 PM
krooozn
Jan 7, 2008 11:06 AM
