swapping complete rear suspension
Old Jan 19, 2021 | 06:57 AM
palolobill's Avatar
ok but it has brembos anyway I bought it for 1000 running after market rims 6000 miles I got it looking for a hhr to swap parts but found an ss with papers non salvage so I'll redo all suspension since bearings and shocks and bushings are worn
Old Jan 19, 2021 | 08:38 AM
Be aware the Ball joints on an SS are different then the LS and LT either just press new bushings into the factory LCA’s or order GM LCA’s specific to the FE5 suspension.
Old Jan 19, 2021 | 08:54 AM
palolobill's Avatar
yes and is the front strut different also?
Old Jan 19, 2021 | 08:56 AM
For a true FE5 yes, there are aftermarket struts like KYB’s that are almost as firm , but are more like a between FE3 and FE5. But they will bolt right in.
palolobill's Avatar
I'm so glad I found this sight dedicated SS /HHR
Old Jan 19, 2021 | 09:06 AM
palolobill's Avatar
thank you guys for your feed back I hope my ignorance isn't that bad I will be looking for your support as I tear more into these cars Mahalos
Old Jan 19, 2021 | 09:44 AM
If you’re restoring the SS we have all the correct information, if you are just fixing it up to DD , we can provide you with that information,also.
Stevovinc28
Sep 15, 2019 08:35 PM
Nodaclu
28
Jan 13, 2019 07:33 PM
Airfoto
Aug 2, 2016 07:14 PM
clintsal
Jun 12, 2016 07:56 AM
rkstevens
18
Apr 18, 2016 11:46 AM
