Top hp
Old Jan 19, 2010 | 04:48 PM
SPPD's Avatar
Originally Posted by stranger
SPPD, not knockin' or yappin' your #'s! All this just adds to the crap that I throw at one of my older brothers 'bout these little hotrods. He doesn't believe the SS is able to out run most of his mid 60's muscle car collection. I personally have out ran his 65 Nova with a zz4 block, chopped rear blah blah blah. (Yea the one I'm tryin' to buy from him) the comment 'bout the bar....you know.....track officials etc.....And d@mn, ya'll puttin' down some good quarter times for a station wagon.
Did not take it as a knock....I just answered Sarcasm w/ sarcasm. Its all good .
Old Jan 19, 2010 | 04:56 PM
SPPD's Avatar
Originally Posted by esmarkey
Which exhaust did you go with and what do you think of it?
You need to update your sig to reflect...
Nothing worth bragging about.
Just had the local muffler shop weld in a better flowing muffler. Its still pretty quiet, but sounds a little better when I jump on it. I doubt if it is giving me any additional HP, and if it is its prob only 1-3 maybe. I have heard that our stock mufflers are pretty good with flow. I will probably add a full Cat-Back at some point w/ 3 inch pipe, but for now this is my DD and dont wanna make the kiddo's go deaf in the back seat. Plus, we have emmissions testing over here so I need to comply with the law
SPPD
Old Jan 19, 2010 | 07:22 PM
foolmoon_design's Avatar
Originally Posted by asanti
09 SS w/ automatic tranny, GM Turbo upgrade w/ Hahn DP and exhaust here. My dyno sheet + vid's are in my gallery but IIRC I put down 260ish hp and 250 lbs/tq at the wheels in my only dyno run. It seemed like there was more power to be put down, but I couldn't fully figure out how to have them run it on the dyno without the TC kickin in in Comp. Mode. If you're looking for Crank HP, that varies w/ the dyno and weather conditions the day you dyno the car. Crank HP is always more than wheel HP due to drivetrain losses.. Crank HP figures typically add anywhere from 18% to as much as 25% over what you have at the wheels (again depewnding on the type of dyno + weather conditions), but the important number is what's produced at the wheels since THAT'S what gets you scootin' down the road quickly!
Later
Allex
Hold down the Traction Control button for about 10 seconds, it completely disables the TC, without having to pull fuses.
Old Jan 19, 2010 | 08:48 PM
Rainman's Avatar
Mine stock Dyno'd out to 244.67 whp and 250.04 tq done at 60 degrees and 20% humidity in April of 09, after all the mods exhaust, stage 1 and new charge piping 276.57 whp and 283.02 tq at 66 degrees and 45% humidity in June of 09 which works out to approx 315 hp per Vince from Trifecta, now after the Trifecta tune who knows, hope that helps.
Old Jan 20, 2010 | 07:17 PM
turbo wanabe's Avatar
Here is what I have, list of mods and dyno graphs. http://www.turbosystem.com/New_Folder/HHR%20SS.htm
PS. car is still for sale.
Old Jan 20, 2010 | 11:05 PM
  #26
Dr_Jekyll's Avatar
Originally Posted by HHRSSouth
Nice, looking forward to the comparison. You getting HPT over the GM stage or Trifecta?
I'm getting HP Tuned by 1BadBlueberrySC from CobaltSS.net.
Old Jan 21, 2010 | 12:22 PM
  #27
asanti's Avatar
Thanks foolmoon, I recently discovered that tidbit and plan on doing just that when I dyno the car again after adding the IC and piping, just debating between Hahn's or Dejon's setups.
Later
Allex
Old Jan 21, 2010 | 01:54 PM
  #28
bartSS's Avatar
I dynod 286hp and 297tq before my HP Tune and ill be dynoing again April 24th so the new numbers will be up then
Old Jan 21, 2010 | 02:33 PM
  #29
SPPD's Avatar
I can't wait to see where your at.
SPPD
Old Jan 21, 2010 | 04:19 PM
  #30
bartSS's Avatar
SPPD
Me either bro. Ill have the new clutch in by then so it should be nice
