Winter Wheels + TPMS
Old Nov 24, 2008 | 10:23 PM
SS HHR CDN's Avatar
I have the sensors install on my winter wheels but it still lights up the warninglight on the dash. How do I clear this?
Old Nov 25, 2008 | 01:36 AM
rockone's Avatar
In order to program the TPMS (sensors) follow the procedure in the owners manual. It's pretty easy. I have done it twice. Once when I put on aftermarket wheels and tires and last week when I remounted the steel wheels and tires.
Here's a summary of the procedure.
Turn the ignition key to the on position, but don't start the car. Press at the same time, the lock and unlock buttons on the key fob, wait for the horn to beep. Then starting with the drivers front wheel, release air until the horn beeps. Once the horn beeps that sensor is programmed. Next move to the passenger front, passenger rear and last the drivers rear following the same procedure. when the last tire is programmed, the horn will beep twice.
Check your tire pressure and you are done.
Old Nov 25, 2008 | 05:36 AM
hyperv6's Avatar
Agreed that is is so very easy even though it is like a GM Chinese fire drill.
It will take you 2:00 or less to reset.
Old Nov 25, 2008 | 08:52 AM
Gone Blue's Avatar
I installed my winter wheels and tires over the weekend for the first time. I bought a set of used 16" HHR steel wheels and struggled over what to do about TPMS. I decided to go with a set from this eBay seller. He has a tab that allows you to make him an offer. My offer of $40 for the set of 4 was accepted which is a great deal for these sensors. I installed the wheels with the sensors for the first time and the sensors immediately started reading the tire pressure. I then programed them per the manual and they are working as they should. I am happy. G.B.
http://cgi.ebay.com/ebaymotors/Chevy...8445QQtcZphoto
gbynum
Tires & Wheels
Oct 26, 2012 12:32 AM
BlackknighT
Aug 19, 2011 07:15 PM
Jeda13
Nov 27, 2009 05:35 PM
Sheverlay
Tires & Wheels
Nov 5, 2009 08:01 PM
