Adding radio buttons on steering wheel
Old 12-04-2021, 04:23 PM
  #841
Cheap Guy's Avatar
Originally Posted by donbrew
Did you read & heed #836?
Yup, it was a calculated risk by going forward, lol. I actually think I was programming the stupid aftermarket interface wrong. If it's working fine with the stock radio, it should work with a properly working or programmed aftermarket steering wheel control.
Cheap Guy is offline
Old 12-04-2021, 04:33 PM
  #842
Between 2008 and 2011 HHR changed the colors and positions of the connectors. My guess is the same with Cobalt. Tell me the year of Cobalt and I can check.
2008 Cobalt is different from 2008 HHR, same as 2011 HHR.
donbrew is online now
Old 12-04-2021, 04:49 PM
  #843
Cheap Guy's Avatar
Said it came from a 2008 Cobalt. Mines is a 2010 HHR LS. Thanks!
Old 12-04-2021, 04:58 PM
  #844
2008 Cobalt
2010 HHR
The only difference I see is the 10 volt ref is 12 V on Cobalt.
Old 12-04-2021, 05:02 PM
  #845
Cheap Guy's Avatar
2008 Cobalt
2010 HHR
Thanks! Sounds like I should be good to go. I'm trying to upgrade the firmware on the Axxess controller and it's not taking so I think that may have something to do with it. Might have to make a run to Best Buy in the morning.
Old 12-07-2021, 05:02 PM
  #846
Cheap Guy's Avatar
Had to go radio silent because this thing was ticking me off. I finally got the steering wheel controls figured out. It wasn't the steering wheel that was causing the problem, it was the install directions for the Axxess ASWC-1 harness that goes along with the GMOS-LAN-03. Contrary to the instructions listed listed below DO NOT CUT THE GREEN/ORANGE wire!
https://metra-static.s3.amazonaws.co...LAN-03_web.pdf
Axxess tech services was extremely helpful once I bit the bullet and called after struggling with it on the weekend. Now everything works fine. I searched online to resolve this and a few others had the same issue. Hopefully this will show up in any related Google search.
One other thing, be careful when you order anything non-OEM online. I ordered a new Pioneer radio harness which I thought was OEM but it wasn't - it was pinned incorrectly so I had to learn a new skill - depinning wires from a harness.
Old 12-07-2021, 06:15 PM
  #847
Did you order that from Crutchfield?
Oldblue is offline
Old 12-07-2021, 06:36 PM
  #848
Cheap Guy's Avatar
😔. No. I was impatient and cheap. Bad combination.
Old 12-08-2021, 06:19 AM
  #849
Thanks for confirming that, the old adage applies, don’t go cheap!
You get what you pay for!
Oldblue is offline
Old 12-12-2021, 01:20 PM
  #850
Cheap Guy's Avatar
Worn button fix
If anyone decides to do the steering wheel replace and the new one has crappy buttons, here's an option I used. Picked this up on eBay for around $10. Only two were really bad but it was bugging me and I wanted to see how it would work. There are YouTube videos on how to replace them - all. I will ad it be careful you don't mess up the good buttons doing this. I scraped a lot of the old paint off but I think all you really need to scrape is enough over the particular indicator on the button. You can use a marker to touch up the little spots too. Let's see how they hold up.
Quick Reply: Adding radio buttons on steering wheel
