Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Aug 13, 2013 | 01:56 PM
  #361
mjo998's Avatar
which solenoid is which?
"Egg - selent"! Thank you very much. I haven't had to completely remove the intake air box ever, so I never saw the "labeling". The auto parts store only had the intake solenoid in stock & I am waiting on the exhaust. Got my fingers crossed that those 4 codes, taken at 2 different times with 2 different types of readers, indicate all that may be wrong with the intermittent hard shifting & occasionally erratic rpm issues.
Old Aug 13, 2013 | 05:32 PM
  #362
The first posting in this thread has been updated to point out the stampings on the top of the valve cover which indicates which is the Intake and which is the Exhaust solenoids.
The easy way to remember is the Intake is the intake side of the engine, and the exhaust is on the backside where the exhaust manifold and pipe are.
Old Aug 16, 2013 | 02:54 PM
  #363
jspocala's Avatar
Originally Posted by whopper
Here is a description of what is involved in the replacing of the Camshaft Position Actuator Solenoids on a 2.4L 2006 HHR (also applies to the 2.2 with VVT, but not the early 2.2's that did not come with VVT).
As of March 2013:
Here is a list from the Oldest to Newest GM Part numbers for the Camshaft Position Actuator Solenoids:
Intake 12628347 = 12646783 = 12655420
Exhaust 12628348 = 12646784 = 12655421
** check the last few pages of this thread for any further updated part numbers in case this has not been updated
and to recap on the CEL codes:
P0010/11 refers to the INTAKE solenoid
P0013/14 refers to the EXHAUST solenoid
NOTE #1: they are SOLENOIDS, not "sensors"!!!! they are two different things!! Several members have purchased sensors in error as advised by an auto parts store who mis-interpret the CEL diagnostic codes
NOTE #2: if you have not downloaded the CEL codes, please do so. If you have come to this posting looking for solutions to hard shifting of the transmission, be aware that there are several other components that can cause hard shifting other than the solenoids. Downloading the CEL codes will clarify where the problem is actually sourced from.
Time: 45 minutes (max.)
Tools used: screwdriver, ratchet with 6 inch extension and 10MM deep socket, small pair of needle-nose vice grips
1a) disconnect the NEGATIVE post on the car's battery (it is in the trunk) - do NOT disconnect the positive post, nor short out the negative post to the positive post - you can get seriously hurt otherwise.
1b) as the air box needs to be removed to get to the solenoids, start with undoing the MAP sensor which is located under the front leading edge of the airbox (press down on the top of the clip to release the lock, and pull gently) - lay the connector aside in a protected spot
Here is a picture of the connector, just to the right of the intake plumbing
2) loosen the intake plumbing from the front of the airbox, by loosing the screw holding the clamp shown in the above picture (at the 7 o'clock position from the MAP sensor)
3) gently work and pull the now loosened pipe free of the airbox (shown here with airbox removed)
4) the airbox is held in place with two grommets at the back of the airbox and one in the front left side next to the rad fill cap. Each grommet snaps onto a short mounting bolt. I prefer to remove the front mount first as it seems more delicate and prone to breaking accidently: you can see the mounting point just to the left of the cap - grab the shaft of the mount from the airbox and pull it free by lifting straight up about an inch or so. Do NOT attempt to pull up on the whole airbox yet. (keep reading)
This is a shot of the grommet mounting bolt with the airbox removed:
Disconnect the rear of the airbox by lifting up on the rearside to free it from the grommets. This is what the grommet mounting posts and mounting bracket look like with the airbox removed:
Note: the grommets that hold the airbox often deteriorate over time, and may not be reusable. Gm calls this part an "Insulator". It's part #12563914, and it's current list is $3.47 as of July 2012 according to one member here.
5) The airbox should now be free of the mounting grommets, the intake plumbing and the MAP sensor, BUT will still be connected to the air intake pipe at the back left side of the airbox - loosen it's clamp and disconnect the pipe from the airbox.
Shot of the intake pipe attached to the airbox - note the clamps screw faces DOWN - Helpful hint: reverse the clamp so the screw is on top to make it easier to disconnect and reconnect with the airbox in place
6) The top of the engine with the airbox removed should now look like this:
Note: the solenoids are on the left side right next to the plug coil pack
7) Remove the connectors at the top of the solenoids (remove them both to prevent accidents) by pulling up on the grey clip until you can work a small screw driver between it and the black lock and remove the grey clip - now you can depress the black lock mechanism to free the connector from the top of the solenoid.
8) Use compressed air to remove any dirt/debris collected around the base of the solenoids.
NOTE: the markings on the top of the valve cover to the left of the solenoids which indicates the location of the Intake and Exhaust solenoids
Close-up shot of the immediate area:
9) Once the area is clean, use a 10mm deep socket to remove the mounting bolt for the solenoid to be replaced. Warning: if you are replacing both solenoids, replace them one at a time to lessen the chance of dropping something down into the mounting holes.
Once the bolt is removed, you should be able to rotate the solenoid SLIGHTLY to loosen it, then pull it straight up and out of the engine. I used a small pair of needle-nose vise-grips to gently get a grip on the metal part of the solenoid and carefully removed it. If you do the same, be careful not to crush the solenoid.
10) Now the solenoid is removed, inspect the cavity and remove any dirt debris that might have "accidently" dropped in - apply some oil to the shaft and o-ring of the new solenoid, and carefully insert it into the engine. Once it is properly in place you will have to give it a downward push to get it to snap into position with the o-ring. Install the retaining bolt and snug it down(sorry, I don't know the torque value - but it is probably about 7-9 ft/lbs my guess)
11) Now do the same with the other solenoid to replace it - remove mounting bolt/pull the solenoid, oil and reinsert the new solenoid
12) re-attach the electrical connectors to the top of the solenoids (make sure you use the correct connector for each one)
13) put a dab of silicone grease on the three mounting studs for the airbox, as well as on the grommets on the airbox - reinstall the airbox.
14) reattach the air intake hose at the back of the airbox and tighten the clamp
15) reattach the pipe to the front of the airbox, and tighten the clamp
16) reattach the MAP sensor to the front bottom side of the airbox.
17) recconnect the negative post on the battery
Done!! Now go fire the car up to ensure it runs.
Whopper, thanks so much. Your detail and step by step instructions helped me save $200. I followed your every word and the superior pictures made it so simple. I made sure to have all of my tools and lubricants ready. It took 45 mins. to do. And my HHR is back to normal. I can't thank you enough. You saved my marriage too! LOL
Old Aug 28, 2013 | 11:40 AM
  #364
San's Avatar
San
Great directions they were a ton of help! Thanks for posting this.
Old Aug 29, 2013 | 03:54 PM
  #365
coolzee's Avatar
I can finally get my car fixed. This the third time at my local wrench to look at this problem. I called them and told to replace both solenoids if they hadn't already!! It has cost me more but the problem will be fixed. Thanks to whopper and to all of the members who contributed to this article.
Old Sep 1, 2013 | 08:58 PM
  #366
J W Davis's Avatar
Yes, thanks to Whopper I too changed mine out myself and saved a ton of $$. Took all of about 30 minutes....Thanks again!
Old Sep 4, 2013 | 04:38 PM
  #367
jackjrw2002's Avatar
Thanks
Thaks for the help I have a 2008 HHR lt 2.4 and the store give me the wrong part in Fl I drove to MO and my engine light came on so I tried to replace the part put was given the wrong part thanks to you I can get the right part and know how to replace the part so TK again Jack
Old Sep 18, 2013 | 05:38 PM
  #368
Kookie's Avatar
Thanks Whopper! Almost just replaced the sensor. Will tackle this this weekend. I'm jealous of the ppl that can get this pair for under $100. Their dealers must be nicer. LoL.
Old Sep 28, 2013 | 10:20 PM
  #369
TkHHR's Avatar
I don't spend much time here anymore but this write up fixed my car and I really appreciate it. Thanks
Old Sep 29, 2013 | 12:14 AM
  #370
Glad we can help guys - and a big thank you to those who have contributed to the discussion with additional tips and hints.
