Changing LED's in Radio, Heater Controls, & Instrument Panel
You can use a 15 Watt Radio Shack one. Just don't want to keep the heat on the board for a long period of time. You should be using a Rosin Core Solder and a little Liquid Flux. You may want to invest in a Desoldering pump, which is also available from Radio Shack......STAY TUNED FOR HOW-TO!!!
Soldering Instructions
When soldering, you have to remember that patience is key and you must not apply too much heat. If your soldering has a temperature control, set to 800 Degrees, no more and no less. This is the optimal temperature for soldering. When working with the Radio LED's which are really small, I applied a bead of solder to the Negative Solder pad first and then heated up and with tweezers moved the LED into the molten solder, while trying to keep the LED flush with the board. Then I applied Liquid Flux to the Positive solder joint and applied a small bead of solder to my soldering iron and then sldered the Positive side of the LED. Once completed I Heated each side and pressed down, Gently on the LED until completely flush. Your patience will be rewarded, I promise. Practice the samel techniques on all the other lights.
Here is the link to the new "How to" Thread:
https://www.chevyhhr.net/forums/how-tutorial-library-21/led-mod-radio-hvac-i-p-step-step-tutorial-2006-2008-a-22174/
! We've installed alot of Mods to our HHR (mostly bolt on) but will probably never have the "BALLS" to attempt something this indepth! I could see us missing parts or smell burning plastic
! Wished we lived Closer
! Anyways to some it up, you have done one "Hell of a Job" and although most would want, most probably won't attempt! Thanks for the Great Write Up also
