Hijacking The Xm Radio Antenna
Old Feb 27, 2008 | 10:25 AM
  #31
tahenke's Avatar
I am resurecting this thread Got some questions. I have an adapter cable that will attach directly to the factory XM antenna. I have an 08 LT with the Pioneer super system and the deck is XM ready and I have the XM/Onstar antenna on the back but I do not have an XM reciever module in the back. I also have Onstar activated. OK, so I was hooking up a SIRIUS Stratus and wanted to tap into the factory antenna because I hate those little magnetic jobbies they give you. The antenna has two leads, Violet and Blue. To my suprise both leads go down and plug into the Onstar box? Thinking that was strange I just disconnected and tapped into the Blue lead and my Stratus just says "Aquiring Signal" and one of my Onstar lights (the one on the right side of the mirror) changes from green to red? So next I decided to try the Violet lead and my Stratus says "No Antenna" so I know I had it right the first time with the blue lead. To troubleshoot further I connected the SIRIUS antenna and all worked well Now I know this can be done because I have done it before on my Chevy Colorado but that vehicle did not have Onstar. Furthermore this thread is about using the factory antenna and it obviously works! The only difference is that this person already had the XM module from the factory. I can't figure out what the difference would be or why both the XM lead and the Onstar lead plug into the Onstar box? Or why it messes with my Onstar when I unplug it? There is an empty/unused plug on the Onstar box (it's not an antenna plug). Does that somehow change how the antenna works and then sends the signal to the factory XM reciever? Is this just another GM ploy to screw the aftermarket consumer and make things so difficult to change that you will finally break down and buy it from them? Truth be told I would have bought it from them if they offered it but they don't, they only offer XM. Please help.
Old Feb 27, 2008 | 05:12 PM
  #32
tahenke's Avatar
Well I have since found out that I do not have the Onstar/XM combo antenna, I have an Onstar only antenna There are a few different versions of the antenna. Thanks to brianrwebb for the info on this. It looks like I'll have to spend some $$$ if I want to use the factory antenna. Last time I bought one it was around $125 for just the XM antenna. I can only imagine what an Onstar/XM antenna costs Anyway, I'll find out and post it here with the part# so the rest of you can benefit.
Old Jul 21, 2008 | 10:10 PM
  #33
bobby dazzlers's Avatar
anyone ever try to switch with one of these?
http://satellite-radio-source.ca/sto...products_id=61
i know that the hhr is not on the list, but it is still concievable that someone has tried it....
thanks!
Old Mar 20, 2012 | 03:21 PM
  #34
kb0sdq's Avatar
This is an old thread but I was wondering, If my 2010 has factory delete for xm & onstar does that mean I can not get xm to work on my gm radio it has the cat button on it. I guess is the unit still installed in the rear quarter panel? and is there a way to install the shark fin?
Old Mar 20, 2012 | 05:35 PM
  #35
If it has the U2K option deleted, there is no module in the vehicle, it will have to be added with the factory kit which includes the module and wiring harness.
https://www.chevyhhr.net/forums/audio-video-17/xm-installed-17272/
Old May 11, 2019 | 02:31 PM
  #36
Tim Heller's Avatar
OMG This is SO Great! I've been looking everywhere for the actual XM tuner location on my 08 HHR SS. This has Finally given me the real location! Thank you! Thank you! Thank you!
Old May 11, 2019 | 04:21 PM
  #37
That's where the OnStar the amplifier is next to the subwoofer on the other side.
Old May 18, 2019 | 03:25 PM
  #38
Musky's Avatar
I'm still trying to determine which trim panel I need to remove from the right (passenger) side of the rear quarter panel to get to the VCIM in my 2008 LT Panel. The diagram that Don posted once helps, but I guess I'm just inexperienced in deciphering them. It shows an "exploded" view of the rear panel and I can't tell where the actual VCIM sits, behind the upper or lower quarter panel trim? Can anyone recommend which service manual I should get? (and learn to read)
Are the CD versions I see on Ebay any good?
Old May 18, 2019 | 04:48 PM
  #39
Just start taking it apart - you will find it. Be adventurous.
Old May 18, 2019 | 04:51 PM
  #40
Originally Posted by Musky;866317? [size=3
Can anyone recommend which service manual I should get?[/size] (and learn to read)
The eBay CDs are available elsewhere for free.
Check your PM.
