HOW TO: bypass valve spring replacement
Old 11-23-2012, 03:39 PM
badassbowtie's Avatar
This is my "how to" on how to replace the bypass valve spring. If you are having intermittent boost issues like I did, its the cheapest place to start.
this might be easier than an oil change
1. purchase a new (I chose stiffer than factory) BPV spring. mine was $13 with shipping from dejon powerhouse.
2. open hood, remove the intake tube(from airbox to turbo) by loosening 2 clamps at both ends
also you will have to remove a braided line that attaches to the tube. you just release the little clip, and the hose should slide off(with some difficuly in my case
3.remove the 3 bolts on the bypass valve
4. mine looked like this when i pulled it out....remove boot and factory spring
and you end up with this
5. put new spring and boot back on
6. re attach the BPV cover with the bolts. this part is tricky because the new spring wants to pop out...I hand tightened the 3 bolts while holding the cover. then cranked the bolts down with a ratchet.
7. re attach the intake tube, tighten the 2 clamps and re attach the braided hose
thats it! about a 15 to 20 minute project for me.....smaller arms may save you a few minutes...
so far this has solved my boost issue where I randomly see 12-13psi at WOT instead of ~19-20psi
badassbowtie is offline
Old 11-23-2012, 04:13 PM
Nice write up. When I replaced my stock one with the Forge unit, I found it easier to use a 1/4" drive ratchet. Then final turn with a box end wrench.
firemangeorge is offline
Old 11-23-2012, 04:51 PM
nice post for how to replace spring, thanks
Oldblue is offline
Old 11-23-2012, 04:55 PM
I should tell everyone that I used a 10mm socket for the bolts...1/4'' drive ratchet is exactly what i used.. thanks fireman and old blue
edit: and i realized that to replace the whole valve wouldnt be much more work....
matt gent
2.0L Performance Tech
01-06-2014 05:40 PM
Turbo_Tomater
05-04-2013 02:51 PM
matt gent
01-16-2013 01:13 AM
BoostedSS
05-23-2011 08:06 AM
Quick Reply: HOW TO: bypass valve spring replacement
