How To Remove Bumper Cover and Bumper Bar
Old Nov 1, 2014 | 09:07 PM
Twistedtat's Avatar
Just another how to on removing the rear bumper cover, and metal bumper bar. Had to replace mine. As always re-assembly is the opposite of removal. Hope it helps someone out.
First unscrew the turn signal lens. Its droops out from the top. Then press the clips here and pull apart. Tuck wire inside.
Next undo the four clips under each fender well. The three outer clips are just the kind where you use a door panel removal tool or screwdriver and pliers. The inner one you have to pry up the middle of the clip and remove it. Then pry up and remove the rest. It's like a push in clip with a retainer ring. Next up in the corner by the edge of the bumper is one 7mm bolt to remove. Pull back on the fender well to see it.
Old Nov 1, 2014 | 09:10 PM
Twistedtat's Avatar
Resized images..
Undo this clip and one about a foot or so apart under the center of the bumper cover.
This one also.
Old Nov 1, 2014 | 09:22 PM
Twistedtat's Avatar
Resized image...
Undo the two T-27 torx bolts on the corners. You get to these by lifting the hatch.
Next the cover will pop off towards you. Best with two people. May have to jiggle it around a little to get it loose. Held on by clips. Oce that is off you will see the actual bumper beam. There are four 13mm bolts inside the four holes as you are standing behind the car looking at it. Unbolt and remove.
Old Nov 1, 2014 | 09:44 PM
Thanks, I hope one of the mods that knows how will enlarge the pics.
Old Nov 1, 2014 | 11:14 PM
Nice write-up there TT
Don, I'll shoot you a PM on the "Quick 'N Easy" way to enlarge a member's images.
Old Nov 2, 2014 | 10:37 AM
Nice "How to" thanks for taken the time to save somebody the headaches you went through!
Old Nov 2, 2014 | 11:40 AM
Twistedtat's Avatar
Donbrew or 843, whoever enlarged my pics a big thank you. I used the direct image link for the copy and paste. Guess that was wrong. Lol.
Oldblue, it really was no pain at all. Just a few tools, panel removal tools, 7mm, 13mm, and t27 torx bit. Oh and you will need a 6 inch extension for the bumper bar. Bolts are mounted inside bar, but very visible through access holes. Total time for swap, 2 hrs. Tops.
Old Nov 2, 2014 | 11:55 AM
Twistedtat's Avatar
This is the 7mm bolt.
Here is a better idea of how the clips are on the bumper cover. I found it to work best if I used one hand on the outside of the cover, the other hand on the inside of the cover to apply even pressure while popping it out.
Old Nov 2, 2014 | 12:19 PM
I'm the phantom image enlarger, once you do it a few hundred times a year, it's almost a reflex action.
When you use the "Insert Image" button on the Advanced Post toolbar, that little dealio that resembles a postcard, make sure you backspace over the extraneous "http://" that it automatically tries to add to any image file.
So when you paste the Direct Image Link, it should look like this for example.....
https://www.chevyhhr.net/gallery/fil...donor_clip.jpg
Which will give you this in your post...
Ta da!
speedwagen
Dec 9, 2012 12:00 AM
Gas Man
"How To" Tutorial Library
May 7, 2012 04:44 PM
87silver
Jul 29, 2011 08:52 AM
Rick's 2LT
Nov 24, 2009 06:27 PM
wyper01
Maintenance and Upkeep
Dec 22, 2008 04:38 PM
