Rear Wiper Mod
Old 09-22-2017, 01:47 AM
Rear Wiper Mod
This is so easy, and when you are done, you'll be able to pull your rear wiper away from the glass, far enough to clean or change it for new, and it stays off the glass until you put it back.
The cover pulls off very easily. Remove it, look on the inside, there is a small tab that you just break off. Then put the cover back on. Here is a pic with the cover off, showing where the tab used to be.
Credit goes to SoCalHHRs, they had a how-to here, but there is no longer any value to it. The pics are gone, the links are dead, so I'm deleting it.
RJ_RS_SS_350 is offline
Old 09-22-2017, 08:15 AM
Good of you to recover that mod...
Greybeard999 is offline
Old 09-22-2017, 08:35 AM
Technical Moderator
However; that tiny tab does help to hold the wiper down. It doesn't do much, but it is noticeable.
donbrew is offline
Old 09-22-2017, 09:55 AM
Wow. That's one of those mods I forgot I had done. I think I did that the 1st week I got my SS in 2010.
firemangeorge is offline
Old 04-29-2018, 10:42 PM
Yep, bout same time frame here as well.
sleeper is offline
JACK-07
"How To" Tutorial Library
30
01-12-2015 08:24 AM
R CA HHR
13
09-22-2007 10:15 AM
JB1
10-02-2006 07:50 AM
flyhhr
26
08-24-2006 08:34 AM
Quick Reply: Rear Wiper Mod
