Remove and replace steering rack
Very true. I have been struggling with a similar highway shake that I thought was due to a bad tire balance but they haven since been balanced and the shake is, while lessened, still there. My intermediate shaft needs doing as well, so I will revisit when I am ready to tackle that project, and the wife doesn't give me grief over spending too much time with Gregg LOL
Today, an inspection of the front end , on the trip to the kids cabin, the front end started to shake but only while deceleration, not under braking. No shake in the steering column, no shake when the brake pedal is depressed, I know it's not the
rotors, new,
brake pads, new,
Front hubs, new,
LCA bushings
Ball joints, new,
Steering rack , new ( included inner and outer tierods)
About the only components that are original are the Drive shafts, I ordered new ones on Thursday, they'll be here on Tuesday.
I'm just gonna re check torque in the steering rack mounts and the rear LCA bolts.
rotors, new,
brake pads, new,
Front hubs, new,
LCA bushings
Ball joints, new,
rotors, new,
brake pads, new,
Front hubs, new,
LCA bushings
Ball joints, new,
rotors, new,
brake pads, new,
Front hubs, new,
LCA bushings
Ball joints, new,
Tire separation
Wheel weights
Since no shake in the steering, you may want to check the engine/trans mounts.
You may find a loose fastener somewhere.
Thanks RJ, tires are just 4,500 miles old, I looked at tires and rotated them on Thursday, same shake on Saturday, I'm thinking axles because, I replaced the hubs before trip to Florida in April, had the same shake, it shook the steering wheel and the rack input shaft was loose and walking a 1/4 inch or more up the worm gear in the input shaft. So I replaced the steering rack, now this shake is at highway speeds when I have to decelerate when I'm approaching traffic or see a Kodiak with a Kodak up ahead.
My thoughts are tire balance would follow the unbalanced tire , when I moved them to the rear.
Engine mounts look good , no flex , and I check torque when I replaced the steering rack.
I'll keep y'all posted
So, on Saturday I replaced the CV driveshafts, thankfully the stub shafts did not pop out, the seals were fine and the left side took two hours then the right side only took 25 minutes.
There was a lot of trial and error figuring out which way to get the shafts out.
I ended up using a flat nail pry bar to apply pressure then push in and pull the axle out with a sudden motion to pop the axle off the retaining ring.
We took a test drive on Saturday and Sunday on familiar roads, no shake or clunks.
Today we took the highway to Hamilton and no deceleration shake , so problem solved!
No more shake & bake!!
