Remove and replace steering rack
Old 09-24-2017, 02:21 PM
  #31
The TTR part?
Oldblue is offline
Old 09-24-2017, 02:23 PM
  #32
GM flat rate.
donbrew is offline
Old 09-25-2017, 07:14 AM
  #33
I saved big time then!
Oldblue is offline
Old 01-25-2024, 04:47 PM
  #34
hhrumadbruh's Avatar
Thanks for the write-up. I may have to do this myself. I took one wheel off and moved the whole assembly back and forth by hand. My clunk/loose area seems to be just under the steering rack boot. Doesnt do it with the front end off the ground, but normally I fill feel a loose clunk if I turn the wheel back and forth. Curious if there is anything I can inspect or not?
hhrumadbruh is offline
Old 01-25-2024, 05:11 PM
  #35
Look at the input shaft to the rack from the steering column shaft, does it move up and down when someone turns the steering wheel, this indicates the rack worm gear is worn out.
Oldblue is offline
Old 01-25-2024, 05:47 PM
  #36
is that the vertical shaft with the ~15mm bolt on it? I didn't see anything move like that.
not sure if this says anything but here's the thing under the boot
Old 01-26-2024, 07:40 AM
  #37
That is the rack part, looks tried and worn.
Where this part slides onto the input shaft, that is a 13 mm head bolt.
Oldblue is offline
Old 01-27-2024, 07:40 PM
  #38
I inspected the intermediate steering shaft. Seemed fine. Noise appears to be coming from the engine bay side of the grommet.
is it possible to remove and disassemble the entire rack and pinion assembly to see what is warn? And then replace only parts needed, or do I need to replace the entire thing?
will post a video in a few minutes.
Old 01-27-2024, 07:50 PM
  #39
Old 01-28-2024, 08:02 AM
  #40
Replace the entire rack. FE5 for the SS model.
Oldblue is offline
Quick Reply: Remove and replace steering rack
