Replacing the TPMS sensor battery
Old 08-19-2018, 08:27 AM
iroga65's Avatar
sensor of order died. I decided to change the battery. Couldn't find the battery number, so used №2032
Soldered to the contacts. Covered with epoxy
Decided to replace the battery. Carefully remove the battery.
The original battery is 2045. I have not found one in our country. Has used 2032.
Gently solder the battery to the terminals. Fill all with epoxy resin.
The sensor is ready for operation.
iroga65 is offline
Old 08-20-2018, 06:48 PM
Blue_SS's Avatar
Interesting. They aren't that much to just replace, are they?
I guess if you hav mad skilz, bro... represent!
Blue_SS is offline
Old 08-20-2018, 07:44 PM
McB_HHR's Avatar
I'm guessing his location makes replacement a pain and/or expensive.
McB_HHR is offline
Old 08-20-2018, 09:30 PM
iroga65's Avatar
I forgot. Has spent 0,5 dollars on the battery and hour of time.
iroga65 is offline
Old 08-20-2018, 10:51 PM
Technical Moderator
iroga65 is in Belarus. American parts can't be cheap or easy to get.
donbrew is offline
Old 02-04-2022, 12:40 PM
PulpFriction's Avatar
In Belarus batteries come from China, just like here.
PulpFriction is offline
Old 02-06-2022, 12:09 AM
mongo's Avatar
It really pisses me off that the batteries aren't made to be replaced.
mongo is offline
Old 02-06-2022, 06:27 AM
You would still need to deal with the bead breaking, and the CR2032 batteries only last a year or two .
I think replacing the sensors every 2nd time you replace tires isn’t bad.
I also think you should check tire pressure every week with a good tire pressure gauge as a better way to ensure you are aware of the air pressure.
Oldblue is offline
ecaryn
05-03-2017 11:35 PM
iroga65
Tires & Wheels
18
04-30-2013 09:19 PM
wayne stewart
Tires & Wheels
0
03-25-2013 02:15 PM
Dennis Puskar
Tires & Wheels
12-27-2011 10:36 PM
BlackknighT
08-19-2011 07:15 PM
Quick Reply: Replacing the TPMS sensor battery
