Water pump replacement
Old 03-06-2016, 08:39 AM
Water pump replacement procedure ALL models and years HHR.
File Type: pdf
donbrew is offline
Old 03-06-2016, 09:08 AM
Thanks donbrew!
RJ_RS_SS_350 is offline
Old 03-06-2016, 03:58 PM
Here is the procedure for those afraid of pdf files
donbrew is offline
Old 03-06-2016, 04:00 PM
Nice post, thanks for the directions!
Oldblue is offline
Old 03-16-2016, 07:11 PM
Here is what the special tool really looks like.
It is available at Advance/AutoZone.
donbrew is offline
Old 03-16-2016, 07:50 PM
Awesome job once again Don!!!
whopper is offline
Old 12-30-2018, 01:48 PM
mamerc's Avatar
That guide pin step really isn't needed, with an extension mirror you can look DIRECTLY at the bolt threads and adjust the pully from the other side of the installed pump spinning the fins. I was surprised how easy it was.
mamerc is offline
Old 12-30-2018, 08:55 PM
Mine is a full circle tool the bolts are clipped into place , the gear to water pump bolts can’t be dropped inside the front cover, and they line up perfect every time, no need to work a flashlight and mirror wand and fumble the bolts!
Oldblue is offline
Old 01-01-2019, 09:53 PM
Horsehaulin's Avatar
What tool is that?
Horsehaulin is offline
Old 01-02-2019, 01:15 AM
Cat Man HHR's Avatar
That's to hold the water pump sprocket in place when the front cover is still on the engine so you can replace the water pump.
Cat Man HHR is offline
Quick Reply: Water pump replacement
