2010 HHR SS - Panel Conversion
Old Sep 19, 2018 | 08:24 PM
10SSPanel's Avatar
More pics...
Old Sep 24, 2018 | 04:48 AM
papa_jo's Avatar
that almost has everything I want!!!
Old Sep 24, 2018 | 05:00 AM
10SSPanel's Avatar
It can be yours and you can add what is missing to make it exactly what you want...
Old Nov 18, 2018 | 01:36 PM
10SSPanel's Avatar
Wow, the rear sway bar makes a huge handling difference!!
Just changed the engine oil and filter again!
Still available if anyone wants a truly well built HHR SS.
The spring seats and cushions were all replaced when the suspension was refreshed.
Oh yeah, I was poking around on this forum and found the threads pertaining to the front lower ball joint not being available as a component. Hmmm got me thinking as I had installed new Moog ball joints when I built the suspension. Now while I have not heard any ‘rattling’ from from the front suspension I realized the Moog ball joint was incorrect so I just purchased and installed new GM OEM lower control arms. I pressed out the brand new rubber bushings in them and replaced with my poly bushings.
Therefore I now have a couple LCA’s with new ball joints and no bushings sitting around!
Old Nov 18, 2018 | 01:40 PM
Always good to have spares, the month after you trash them, sell them or give them away, a nasty pothole or curbing will bend one for you!
Old Nov 18, 2018 | 01:49 PM
  #26
10SSPanel's Avatar
Problem is these LCA’s are no longer useful on a SS (the ball joint shaft is sized for everything else that uses this suspension). I would think they could be used as an upgrade for the steel ones on lesser HHR’s?
My HHR is one of 10 cars I currently have and only gets driven once in a while for a Costco run! Looks like it won’t sell which is fine, I have space for it in my garage (all 10 cars are indoors). Many years from now it will still be a low mileage HHR SS converted to Panel in the same condition it is right now!
Old Nov 18, 2018 | 02:36 PM
  #27
Even us “lesser” HHR’s all got the aluminum LCA’s , you could sell them to someone with an LS/LT wanting to install the bushings
Old Nov 18, 2018 | 03:29 PM
  #28
Ohiocruiser's Avatar
not that I am questioning your statement. Would be cool to see what kind of cars do you have In that garage
Old Nov 18, 2018 | 03:59 PM
  #29
10SSPanel's Avatar
‘73 240Z Chevy V8 6 Spd
‘07 Z06 657 rwhp Honda VTX 1300 d Night Rod
‘96 CE Corvette
‘07 Escalade
‘09 Jaguar XKR Portfolio
‘02 Silverado supercharged and lifted
‘13 ZL1 ‘90 300ZX
‘13 Z28 clone
Old Nov 18, 2018 | 04:04 PM
  #30
10SSPanel's Avatar
I like improving suspensions on cars, everything gets poly bushings etc. No matter the car it can be made to handle better than stock. The ‘96 Corvette handles amazing as does the ‘09 XKR after suspension overhauls.
No bs, I don’t fool around or spare expense, they all get built right!
I buy what I like and fix it up to make it the way I want it.
Good way to de-stress from work. I built myself a shop to escape to on the weekends.
