just picked up a 2006 HHR LT with 178K miles. Bought off Craigslist, picked up in the dark, all kinds of things you shouldn't do when you buy a used car.
When I picked it up, it started right up. we did the paperwork and I came back outside and it wouldn't start...Ended up jumping the terminal under the hood with my son's 2022 Jeep and it started up. I saw a lot of corrosion on the terminal that could have been the problem. Drove home about 55 miles and it ran just fine, Had to do some searching for the window switches, and found the cruise which worked. Once I got home, I looked at the trailer hitch and noticed a chrome bar that locked the hitch together, I didn't get a key.. so I may have to use the fire wrench to get that removed.
Expect a lot of questions as I know nothing about these critters other than I like the looks of the body.
Thanks, maybe I can get the 1 7/8 ball off and just put on a 2" which will work for my trailer and leave it on there. it doesn't stick out that far I guess.
After a quick bath and some more scrubbing. we found that it leaks on the front floor, I am guessing the door seals weren't sealing because of the dirt and grime buildup. it has been sitting for quite some time in a garage I think. no mold or damp smell inside when I picked it up.
Maybe I am getting used to it, or maybe washing it helped, but it isn't so bad now. Still leaning towards adding another color , maybe some black or creme to it..
OK Thanks! It does look like it has been parked for a while with all the dust/dirt and grime that accumulated. it took a bit of scrubbing to get most of it off. Not sure if I can do much with the butyl patch since it has hit the high for today of 37 degrees, but at least water won't run in
