New Guy with Questions
Thanks! yea not concerned with warranty as its already up. Is there anything i can do with my HPtuners today to get a little more power out of it with the stock setup, until i can order parts and whatnot. Just trying to do something on it since i already have HPtuners. Any place to DL Tune files on this site? and someone was saying to do an ethanol tune? i dont have e85 where im located. thanks
Unless you are over 100k
Theres a tuning guide on hptuner forum for the lnf which is pretty simple to follow. Just letting you know a lnf has more to do then tuning a ls1(had 98 z28 myself). A intake would do if you want to hear the stock bov and turbo spool. If you want to be like everyone esle. I did a Bov greddy type s and it is not that hard to do. Youll need a block off plate for the stock bov, upper piping with a flange of bov you are using, and a tune for it cause it will miss with your fuel trims. Some will say you will need to relocated the maf but you dont have to its all in the tune. Heres my bov:
http://youtu.be/1jtKIncodG4
http:
//www.hptuners.com/forum/showthread.php?t=26756
Also great for understanding what is going on but the DAL he uses is way more linear now.
http://www.hptuners.com/forum/showthread.php?t=26232
Also watch out for tunes that are E47 or E85 I don't think you ant to use their fuel tables but check the other tables 'cause there's always some eye openers there.
Don't have my laptop with me or I'd link you to some good starting points. Can't find them right now in the HPT forum but I'll keep looking.
Oh, and check your speed limiter too, I bet it's set to 132 mph.
Found it!
http://www.hptuners.com/forum/showth...t=35111&page=4
Mind you it's an E47 tune but note the tables and compare to older ones. Lot's of great stuff here! Also the cam tables used if you want to disable the Cat Warmup.
I'm sure I'm not making friends with the "pay to play" crowd but don't care, they stopped responding to my posts a long time ago. I really should start a new thread with this so everyone with HPT can play.
Found it!
Your getting unfiltered air from the fender well now. Big debate on the lid. Best of both worlds... Raise the lid about a half inch with spacers, then you can fit a K&N filter without crushing it. Reward, is better sucking sound, BPV, and Turbo whistle. debatable downside.. hot engine air.
Found it!
Found it!
