Air-less Tires
Nothing new here. They've been playing with this technology for at least 10 or 15 years that I know of. The potential is there. When you think about the number that don't bother to check tire pressures (we see 'em every day!), plus this could eliminate the need for a spare tire and it's weight and space requirements.
My only question is: How the heck to you fill 'em with NITROGEN ???
The tire is called the "Tweel".
Yep, the same pic can be found in the 2nd of the two following threads
https://www.chevyhhr.net/forums/showthread.php?t=2011
https://www.chevyhhr.net/forums/showthread.php?t=9194
How would these tires look on the SS?
SEE THROUGH TIRES
Radical new tire design by Michelin. The next generation of tires. They had a pair at the Philadelphia car show.
Yes, those are 'spoke' like connections to the inner part of the tire from the outside tread 'wrap!'
These tires are airless and are scheduled to be out on the market very soon.
The bad news for law enforcement is that spike strips will not work on these.
Just think of the impact on existing technology:
A. no more air valves...
B. no more air compressors at gas stations...
C. no more repair kits...
D. no more flats...
These are actual pictures taken in the South Carolina plant of Michelin.
D. no more flats...
