06 HHR spark Plugs
Old Oct 3, 2017 | 05:11 PM
Originally Posted by donbrew
Because Anti-seize encourages over tightening. The plugs are steel, the head is aluminum alloy. If you King Kong the plugs in you can easily pull the threads out of the head.
Yep, like oldblue said, 15 lbs ft. Which is not very tight!
Old Oct 3, 2017 | 05:53 PM
Conax's Avatar
Really? I'm buying stock in heli-coil right away!
These cars are unique. Nothing you ever did to a car is the right way on these things.
I have a bit of oil on mine, seems to run perfect.
Old Oct 3, 2017 | 08:37 PM
Have you read the correct brake bleeding sequence? X, not RLRL.
Old Oct 3, 2017 | 09:51 PM
Originally Posted by SteveMaine
What is the best plugs to put in my 06 HHR larger engine. Thanks
Well. The answer seems to be the same as when you ask this question 4 years ago.
https://www.chevyhhr.net/forums/main...k-plugs-48562/
Old Oct 3, 2017 | 10:10 PM
Good catch FMG! Steve, these plugs are good for around 100,000 miles. If you put these in 4 years ago, you shouldn't need new ones yet. Are they misfiring?
Old May 6, 2018 | 05:54 PM
threads merged
Old May 6, 2018 | 10:28 PM
New spark plugs come coated, so nothing else is needed.
And I always check the gap, no telling if they have been banged around in their lil boxes prior to getting bought & installed. But that's me.
Old Feb 16, 2020 | 07:54 PM
WendySaree's Avatar
Spark plug gap
Can I use .044 gap plugs in my 2010 hhr lt 2.2? The owners manual says it should be .040 and ever since I put new ones in it I have a surge or stuttering around 50 mph idk what to call it.
Old Feb 16, 2020 | 08:39 PM
Did you install the recommended ACDelco 41-103?
Old Feb 16, 2020 | 08:46 PM
x2 what RJ says- ACDelco 41-103 are the correct plugs (accept no other brand).
they come pregapped so just them as they come out of the box.
BTW: there is no such thing as ".044 gap plugs", if you mean can you regap the ACDelco 41-103 to .044" - no. If you mean you have a different brand of plug and they are already gapped at .044" then you have the wrong plugs.
