Alternator question
Old Dec 6, 2017 | 01:12 PM
hurst2001's Avatar
Originally Posted by Oldblue
This is 2007 AC Delco , and the same picture for 2011
So they could be stock photos, some on parts websites show 120 amp some show 130 amp ratings
Ok guys I was useing this from harbor freight and the way I read it was charging inadequately.. ok today I took out my volt meter here is my reading overnight 12.2 startup 14.6 load 14.4 lights radio defroster .. so it seems to me everything is good according to the volt meter .. it is freezing out here in Chicago .. so I think I will buy a back up alternator 2007 with 33k and have it on hand just in case .. thanks
Old Dec 6, 2017 | 01:31 PM
If the only reason you have is that sensor, don't worry.
The way the computerized regulator works is different from the "old days". It also takes economy into account, it is not always generating.
However 12.2V is showing an older battery. The alternator will not work with a bad battery, it takes a signal in order to generate.
Old Dec 6, 2017 | 01:45 PM
Cat Man HHR's Avatar
Originally Posted by hurst2001
I was useing this from harbor freight and the way I read it was charging inadequately.. I took out my volt meter here is my reading overnight 12.2 startup 14.6 load 14.4 lights radio defroster .. so it seems to me everything is good according to the volt meter
But it's charging. What are you afraid of? Forget that Harbor Freight junk, your volt meter is telling you the real deal. How old is the battery? Cold temps will kill it fast if it has some time on it.
If you really want to load it, turn on everything that's electric. Lights on high beams, defrost (it uses the AC), rear window grid, wipers and interior lights. Then see what your voltage output is at idle and above.
Is the belt original?
Old Dec 6, 2017 | 01:52 PM
Don at a 12.2 volt signal to the alternator it will charge. It will excite the field winding thru the internal regulator. You have an output of 14.6, it's working.
Old Dec 6, 2017 | 03:12 PM
I was just adding superfluous info, like dead/no battery.
Old Dec 6, 2017 | 03:18 PM
My battery read the same 12.2, and it wasn’t strong enough to last another three days.
Cold will kill it.
I replaced the battery did a retest if the charging system and it’s just fine
Original 10 year old Denso OEM alternator 255,000 miles!
Old Dec 6, 2017 | 04:34 PM
hurst2001's Avatar
Cold will kill it.
I knew not to trust that harbor freight sensor that’s why I use a volt meter for sure , I think the battery is 3/4 years old so .. but it starts up on a dime no hesitations at all just don’t want to get stuck in the cold got to say we got the best alternator from the factory mine is pushing 252000 and still going
Old Dec 6, 2017 | 08:37 PM
Wholesalegmpartsonline only lists a generator for 2006-2007, GM P/N 10355395. They do not show a generator(or alternator) for 08-11. This is the same GM number for oldblue's first link, 120 amps.
The second link, 130 amps, has a GM P/N 15923218, which I can't really get any GM type site search results.
Oldblue's site doesn't have a generator for the 2.0....
-md- HHR
2.2L Performance Tech
28
Jun 12, 2008 12:57 PM
JT's HHR
Jan 24, 2008 01:15 AM
betterof2evils4
Sep 26, 2007 10:22 AM
bowtiebandit
Dec 18, 2006 08:17 PM
Copperhead
Sep 5, 2006 09:44 AM
