I received a promotional code 24H from PolishAngel USA therefor I will be testing polishangel primer and polishangel cosmic spritz when temperature allows it (this spring). Will then use angelwax and then, perhaps, the tonus from silverwax.
I had to rename my picture. There was the symbol "+" and apparently it is what is causing the trouble.
Here is my HHR after a quick polishing with polishangel, cosmic spritz and then dark angel from angelwax. I think it is the best result I had so far. I did the same steps from one of the shared video above :
It's the exact same steps followed by this user in this video here :
