Blinker problem, need advice
Old Nov 18, 2015 | 09:01 PM
If a turn signal bulb is burnt out, or has a problem with the connection going to the non-flashing bulb, the front light and indicator light on the dash will flash very fast. If it doesn't flash quickly, then the problem is upstream - ie: the Body Control Module.
At least that is my theory.
Old Nov 19, 2015 | 11:21 AM
And my train of thought is if that is the case, a battery lobotomy is in order! To reset the BCM and while that neg cable on the battery us disconnected for 20 to 30 minutes, check those ground wires in near the back taillight area
Old Nov 23, 2015 | 01:29 PM
alexrckid's Avatar
at least two years ago, had the "non-canceling" right turn deal......did the fix as illustrated in this forum...............have not had any problems since. this site has fantastic info....thank you.......
macbdog
Mar 1, 2013 06:20 PM
geekdad
Apr 17, 2007 12:45 PM
eat_world
Feb 9, 2007 08:31 PM
hvrod
Jul 13, 2006 01:04 PM
omega015
Feb 18, 2006 11:06 AM
