Brake Fluid warning
Old Jan 19, 2020 | 04:35 PM
Flyinmech's Avatar
Brake Fluid warning
Only got this after it turned cold here. Comes and goes, never had a car or truck do this?
Old Jan 19, 2020 | 05:09 PM
Cat Man HHR's Avatar
Originally Posted by Flyinmech
Only got this after it turned cold here. Comes and goes, never had a car or truck do this, spelling stinks, fluid
Read though this, some people had the same problem when temperatures were cold also.
https://www.chevyhhr.net/forums/prob...-warning-6754/
And then you checked the brake fluid level and found ..............?
Old Jan 20, 2020 | 12:01 AM
geg's Avatar
geg
Just for fidelity again
ChevyMgr wrote
Automatic Transmission Should be MN5 Auto Transmission Master Cylinder Brake Fluid Reservoir KIT Part # 15939572
Manual Transmission Should be M86 5-Sp Manual Transmission Master Cylinder Brake Fluid Reservoir KIT Part # 15939485
https://www.chevyhhr.net/forums/problems-service-repairs-42/brake-warning-low-brake-fluid-abs-fault-6720/page2/#post238012
Guys from Belarus say they have solved this problem.
The original brake fluid reservoir had a poor design - a “cold problem" as a result. Just replacing the reservoir into parts with numbers.
LVJJJ
Sep 23, 2016 08:13 PM
Beachbum1
May 15, 2015 06:15 AM
hozer
Maintenance and Upkeep
12
Mar 16, 2014 07:06 AM
fastsuv
Feb 22, 2013 10:36 PM
