Brakes and abs question
Old Mar 19, 2019 | 07:52 AM
Cat Man HHR's Avatar
Originally Posted by Krunk
You "should" open the bleeders. Reason being is if you push the fluid back in too fast, you can screw up seals and filters, and if there is crud in the system, it can stir it up and also mess up filters. The system is not serviceable so that means replacement.
Can you tell me where the filters are in the brake system ?
And what seals will be damaged ?
Thanks
Old Mar 19, 2019 | 10:16 PM
Krunk's Avatar
Afaik, the system may not be serviceable. If you have a manual, you should be able to see if it is serviceable and what parts it would need.
http://my.cardone.com/techdocs/PT%2012-0001.pdf
Old Mar 20, 2019 | 05:37 PM
Blue_SS's Avatar
Thanks
There are none in that system. We are putting them into the MC reservoir just now on new models, and that is just to keep crud from getting down into the lines. There is nothing within the system.
When I was doing competitive stuff (different vehicle), I bled my brakes a lot. 4-5 times a year. I got speed bleeders and did it myself. However, if you aren't building up racetrack-type temperatures, or dumping cocoa powder into the reservoir, I wouldn't sweat it. If your pedal feel remains good, you are fine.
A vote for "if ain't broke, don't fix it."
Old Mar 20, 2019 | 06:13 PM
Blue SS
When I asked those questions I wanted to see if that person could give proof positive of what he posted.
Old Mar 20, 2019 | 06:24 PM
hurst2001's Avatar
So are systems are fine not to open bleeder and just push the piston back in ? Or we should clamp the hose off and then open the bleeder and then push the piston back in ? Confused..
Old Mar 20, 2019 | 07:27 PM
For all intents and purposes , either way.
Old Mar 20, 2019 | 10:14 PM
Krunk's Avatar
Well Cat Man, not sure about your axe, but this info has been around a long time. If you don't care, then don't do it. But I didn't just make it up.
https://www.bobistheoilguy.com/forum...Number=2155122
Old Mar 21, 2019 | 05:13 AM
Krunk
Done many brake jobs. No, I don't open the bleeder to retract the piston. And never have damaged the caliper or master cylinder.
The only "filter" I know of is a screen type basket on the top of some master cylinders.
And your quote " if there is crud in the system". The only "crud in the system that I know of is if the brake fluid absorbed moisture and the fluid turned brownish. Then flushing the system is required.
Old Mar 21, 2019 | 07:17 AM
Krunk's Avatar
I've done many brake jobs, too. On abs, and non-abs systems. I have always opened the bleeder, and for good reason. Water is heavier than brake fluid, so where do you think it is going to sit? In the calipers, since they are the lowest point of the system. I've rebuilt calipers because people don't bother to bleed their brakes in timely fashions, especially if they live in humid climates. But, you do whatever.
https://books.google.com/books?id=mN...piston&f=false
https://www.knowyourparts.com/techni...rake-calipers/
https://itstillruns.com/how-to-chang...-12259264.html
But again, you do it how you want. I won't bother with this anymore. I've made my position clear and posted the reasonings behind it.
Old Mar 21, 2019 | 08:59 AM
I say do whichever way you like. It's your car.
As far as water being heavier than brake fluid. If that's the case, then water would settle to the bottom of the caliper. BUT, the bleeder is on the TOP of the caliper. (although, I always assumed that moisture would mix with brake fluid and didn't separate)
Just saying. Not arguing the facts.
Fwiw. I was in the repair biz years ago. Done literally hundreds of brake jobs. Hardly ever opened a bleeder when replacing pads. I have opened many though if needing to bleed the system.
