Brakes and abs question
Old Mar 21, 2019 | 10:38 AM
Cat Man HHR's Avatar
Thanks George for your input.
I like the water comment. Yes water mixes with the brake fluid but doesn't settle to the bottom of the caliper or wheel cylinder.
If the guy wants to test his theory. Get a clean glass jar put new brake fluid in it add some water and mix it up. See if it settles out.
Use Dot4 or the newest stuff Dot 5.1
Old Mar 21, 2019 | 11:22 AM
In fact, if you pour an oz of water into a glass of brake fluid the level of fluid in the glass will not rise! Just like alcohol the water combines with the brake fluid (forgot the real word).
Old Mar 21, 2019 | 12:14 PM
Don
The word is absorption. Lol.
Old Mar 21, 2019 | 05:10 PM
Blue_SS's Avatar
The fluid is also called hygroscopic, meaning it attracts water from its surroundings.
I am not against flushing the system after years of use, but I don't normally do that when I am doing brake pads and or rotors. It's a closed system, and should stay free of moisture if you don't mess with it.
That includes "topping it off" when it's low. It is low in the reservoir because your pads are worn. Once you do compress those calipers, the fluid goes back to the reservoir. If you topped it off, it is now over-filled, and brake fluid comes out of the cap, and it can eat the paint off your booster and other things. Just don't top off. If it is actually low on fluid, you have a leak, and that is serious, but you should see signs at one of the wheels easily.
Old Mar 21, 2019 | 05:24 PM
I once was talking to transmission mechanic about my hydraulic clutch, the truck had a separate reservoir. When I told him I suspected my clutch was getting to EOL because the fluid was getting low with no puddles he was absolutely astounded and asked "where is it going?"
DOT 5 is not recommended, unless the car came with it. Not compatible with 3,4 or 5.1. DOT 5 is not the same as DOT 5.1
questionMARK
Oct 21, 2016 02:27 PM
rjdelapp
Jul 26, 2012 10:56 AM
helhedded
Mar 22, 2012 06:55 AM
5speed4
Aug 12, 2011 03:28 PM
5speed4
Mar 13, 2008 09:12 AM
