Brown spark plugs and an intermittent rough idle
Old Mar 23, 2026 | 07:22 AM
Nice! I just installed a drop in K&N filter in the factory air box!
Old Mar 23, 2026 | 11:22 AM
chaosdsm's Avatar
I did that for about 2 or 3 years, but I hated having to pull the whole box and take out the screws just to clean the filter, which is also a lot of extra wear & tear on the air hose. With Florida basically having heavy pollen seasons in both spring and fall, I like to clean the filter around mid May, and again around mid November. It's so much easier to just unscrew that one hose clamp now!!! Don't know that it was worth $300, but don't regret it either
Old Mar 23, 2026 | 02:11 PM
I did have a K&N air box on Oldblue, two screws and a hose clamp to remove the washable filter.
As for the wooly worm hose, I’ve replaced that with metal dryer vent hose. Much better!
Old Mar 23, 2026 | 08:05 PM
chaosdsm's Avatar
Unfortunately, even that gets worn out with enough remove / re-attach cycles. My dryer vent duct has a hole in it near the intake where it split at a seam. Trying to see if I can figure out a more permanent fix that won't cost much more than another piece of dryer vent!
Old Mar 23, 2026 | 09:33 PM
Duct tape, if want to worry about it. Not a big deal, the air from the wheel well is a bit cooler than under the hood.
Old Mar 24, 2026 | 02:59 PM
chaosdsm's Avatar
Not really worried about it, but supposedly, holes in the duct can create chaotic airflow that disrupts the engine's ability to measure and ingest air accurately, which can then lead to inconsistent air-fuel mixtures...
Old Mar 24, 2026 | 07:48 PM
Don't know where you heard that. The filter would calm that down
Old Mar 25, 2026 | 11:52 AM
chaosdsm's Avatar
O'reilly & Autozone.... probably just trying to get more sales. That would be my thinking as well, & even the temp difference between the wheel well air & the engine air isn't huge especially since the hole is about as far from the engine as it can be while in the engine compartment, which is also why I'm not really worried about it.
Old Mar 31, 2026 | 03:56 PM
PulpFriction's Avatar
Factory-looking wooly worm $29 on Amazon.
Old Apr 25, 2026 | 08:52 PM
KrazyFokcer's Avatar
Mine will be delivered tomorrow. Since we got our hours cut, I got two days off,so I'll be installing this and I may do my temp sensor and thermostat with a flush. Really not sure what to do with two days off though, haven't had this since mid 2025!!!! I'll probably tackle my wife's Rogue doing her side moulding clips along with installing quick release bands on her front bumper but got to get all of the adhesive off the paint. Google says WD40 works best removing the adhesive, does anyone know anything better. Here is a picture of what I'm working with. The mounting tabs under the headlight are broken and plastic welding did not help. So I've taped up both sides so this is a fairly large project. I also have to worry about the fender moulding on the right side too. Spill know more tomorrow since it has been a minute since I've taped it up. The wife is off "Monday" so I'll have her out there with me Sunday afternoon when she wakes up, hehehehe. Thanks for reading and have a great night/day.
