Brown spark plugs and an intermittent rough idle
Old May 6, 2026 | 12:17 PM
KrazyFokcer's Avatar
I ordered, received, and installed my new intake hose. In the process I broke my oil filler neck. Luckily the cap will screw directly into the intake. I'll acquire a replacement here in the near future.
Anyhow, got it installed and seems to be working out. In another forum I went through my coolant temperature sensor and thermostat issue and change, and once I reset my CEL that came along with the thermostat change.
The intermittent idle issue has been a non-issue lately. Which I find as a good thing. So changing the plugs awhile back fixed the issue.
As far as installing an aftermarket cold air intake, nah, I don't like the way they sit. I may get with my brother and see if he can help fabricate one that'll sit into the passenger fender well next the the radiator cap. Main issue I've noticed is the MAF sensor placement. The wiring is to short, so I'd have to extend the wiring and fab the plug in tats on the OE air box onto the new intake.
Anyway, seems that everything is going well, just hope it all stays that way. Fingers crossed!!
Old May 6, 2026 | 01:35 PM
ZZP sells an extended MAF sensor cable
https://zzperformance.com/products/m...ension-harness
Old May 7, 2026 | 11:18 PM
Cool, thanks. They have some good items after going through the website. Lots of good products.
Old May 12, 2026 | 09:07 AM
Vinnybagodoughnuts's Avatar
Factory-looking wooly worm $29 on Amazon.
I have this on my HHR. Pretty good quality for the price although they do use staples to hold the fittings on the tube.Haven't had any problems with it in the year it's been installed.
brad594
Feb 3, 2026 01:22 PM
Yefet
Jan 24, 2023 03:48 PM
farmboyhhr
2.2L Performance Tech
20
Jan 10, 2015 01:30 PM
blacky
Maintenance and Upkeep
12
Aug 30, 2013 09:30 AM
Zagohhr
2.4L Performance Tech
14
Aug 27, 2013 12:39 PM
