Can't pinpoint what sounds like a bearing issue!
Old Feb 12, 2023 | 10:36 AM
Originally Posted by MJR1970
The 986m_ax is what is written on my actual part & the carton itself. I have an 08, automatic, 2.2 engine. So it has to be the right part. The new part doesn't have a removable stub, it is made with the stub.
But you haven't made clear which side you are trying to replace.
Old Feb 12, 2023 | 10:40 AM
MJR1970's Avatar
Originally Posted by Oldblue
Can you post a photo of the actual part you ordered and the part number on the packing slip or the carton the new axle came in. The photo you posted could be a file photo, and I can’t really see the transmission end
To confirm RJ , the Detroit Axle site shows 986M-AX
https://www.detroitaxle.com/part/cv-...-axle/986m_ax/
I have the same part number on my new part. The inner end is splined but not removable. Maybe they make them with the stub permanently attached now?
Old Feb 12, 2023 | 10:42 AM
MJR1970's Avatar
You say you've replaced the passenger side hub twice recently. Oldblue's suggestion of driver side hub should be considered.
Yes sir, I'm probably gonna go ahead and order one for driver side. Crazy how sound can originate and travel to another location.
Old Feb 12, 2023 | 10:44 AM
MJR1970's Avatar
sorry, I want to replace passenger side CV axle.
Old Feb 12, 2023 | 11:19 AM
The axel has the stub shaft with cup seal already installed, you will have to remove the old stub from the transmission. I’ve used vise grips and a pry bar, a quick movement should pop it out.
Old Feb 12, 2023 | 12:07 PM
  #26
MJR1970's Avatar
Thanks! I wondered if it would be difficult to remove if it didn't come out with the old axle.
Old Feb 12, 2023 | 04:59 PM
  #27
The trick is a sudden motion to get the spring clip to release the stub . It’s easier if the opening of the ring is at 6 o’clock that way the solid area is down in the groove
Old Feb 12, 2023 | 05:43 PM
  #28
MJR1970's Avatar
DUde thanks!
Old Feb 12, 2023 | 07:40 PM
  #29
Old Feb 13, 2023 | 02:51 AM
  #30
PulpFriction's Avatar
A bad tire cam make a roaring noise. Always check the tires first before replacing parts due to noise.
