Can't pinpoint what sounds like a bearing issue!
But you haven't made clear which side you are trying to replace.
Can you post a photo of the actual part you ordered and the part number on the packing slip or the carton the new axle came in. The photo you posted could be a file photo, and I can’t really see the transmission end
To confirm RJ , the Detroit Axle site shows 986M-AX
https://www.detroitaxle.com/part/cv-...-axle/986m_ax/
The axel has the stub shaft with cup seal already installed, you will have to remove the old stub from the transmission. I’ve used vise grips and a pry bar, a quick movement should pop it out.
Thanks! I wondered if it would be difficult to remove if it didn't come out with the old axle.
